F-8J APQ-124 MAGDARR question
Any of you F-8 guys have experience with the J's radar? I
have a source which states (and has a photo of what is stated to be the APQ-124 control head indicating the same) that the APQ-124 had a Pulse-doppler mode as well as Pulse, similar to the APG-59 of the F-4J. Was this mode actually available on the APQ-124 and, if so, how well did it work? TIA, Guy |
"Guy Alcala" wrote in message . .. Any of you F-8 guys have experience with the J's radar? I have a source which states (and has a photo of what is stated to be the APQ-124 control head indicating the same) that the APQ-124 had a Pulse-doppler mode as well as Pulse, similar to the APG-59 of the F-4J. Was this mode actually available on the APQ-124 and, if so, how well did it work? TIA, Yes. We're workin' with 29 year old memories here, Guy. Last flight in March 1976. No, the radar didn't have a PD mode. IIRC, there was a switch position (non-functional) for PD, indicating that the designers intended to have it. Given the lack of a radar missile (AIM-9C notwithstanding, never carried it, never even SAW it), pretty much a moot point. Not a great radar (albeit better than that installed in the D/H and C/K). Our intercept doctrine could be described on a business card: "Give us a Talley Ho!" R / John |
John Carrier wrote:
"Guy Alcala" wrote in message . .. Any of you F-8 guys have experience with the J's radar? I have a source which states (and has a photo of what is stated to be the APQ-124 control head indicating the same) that the APQ-124 had a Pulse-doppler mode as well as Pulse, similar to the APG-59 of the F-4J. Was this mode actually available on the APQ-124 and, if so, how well did it work? TIA, Yes. We're workin' with 29 year old memories here, Guy. Last flight in March 1976. No, the radar didn't have a PD mode. IIRC, there was a switch position (non-functional) for PD, indicating that the designers intended to have it. I wondered if that might have been the case, kind of like the APS-107 (actually an RWR not a radar) switch in the air force's F-4Es-- the system was never installed in the F-4E. BTW, your memory is quite accurate. The radar function switch has positions labeled OFF, STBY, PULSE, PD (this and PULSE under an arc labeled OPR) and EMER. Given the lack of a radar missile (AIM-9C notwithstanding, never carried it, never even SAW it), pretty much a moot point. If the PD mode had actually been available and worked, I'd think look-down capability would be useful. But that assumes that it and the F-4J's APG-59 PD mode worked looking down over land. Anyone care to comment on how well the Phantom's PD mode worked (when the radar worked at all, that is) over water and land? Not a great radar (albeit better than that installed in the D/H and C/K). How'd the APQ-94 in the E stack up,and what if any changes were there between it and the J's -124? There's also mention of an APQ-149, which may apply to the F-8H as an upgrade of the APQ-83 in the D, as they use the same control head. snip Guy |
Similar Threads | ||||
182RG question | Paul Anton | Owning | 11 | May 16th 05 09:45 PM |
Good morning or good evening depending upon your location. I want to ask you the most important question of your life. Your joy or sorrow for all eternity depends upon your answer. The question is: Are you saved? It is not a question of how good | Excelsior | Home Built | 0 | April 22nd 05 01:11 AM |
VOR/DME Approach Question | Chip Jones | Instrument Flight Rules | 47 | August 29th 04 05:03 AM |
Legal question - Pilot liability and possible involvement with a crime | John | Piloting | 5 | November 20th 03 09:40 PM |
Special Flight Setup Question (COF) | Dudley Henriques | Simulators | 4 | October 11th 03 12:14 AM |
