Landing Brookhaven MS - Video
Old September 4th 08, 03:10 AM posted to rec.aviation.ifr
Default Landing Brookhaven MS - Video
Startup, runup, take off enroute and landing at 1R7 Brookhaven MS and
landing KMBO Madison MS
Text overlays on what I am doing for startup, runup and listening to
AWOS.
http://www.youtube.com/watch?v=A7f3DTmQOO8
Old September 5th 08, 03:51 AM posted to rec.aviation.ifr
Kobra
AWOS.
Some questions and suggestions.
Does your camera have an input for an external mic. Mine does (Canon HG10).
I use a condenser mic (tie-clip mic) and put it inside a Bose X headset that
I rubber band closed nice and tight and I plug the Bose X into the backseat
jack for sound only, I do not plug the Bose X mic cord in. I have to
disable the auto-shut-off so the Bose stays on else the ANR cuts off.
This gives a great quiet cockpit with clear communications heard with ATC
and the intercom.
How did you stabilize the camera? Did you use a tripod or just duct tape it
on the glareshield?
Do you use a wide-angle lens?
Why don't you take the prop balance sticker off? It's not necessary any
more and it keeps the viewer's eye from being distracted by the flashing
white square going by.
I don't know why your prop is so visible. Mine doesn't do this. It looks
in the video just as my eye sees it. Maybe your frame rate is too low? Can
you increase any settings to get a faster frame rate?
Happy flying and video making!
Kobra
Old September 5th 08, 04:20 AM posted to rec.aviation.ifr
On Sep 4, 9:51*pm, "Kobra" wrote:
Hey Gene,
Appreciate the feedback!
No, it's just a point and shoot Kodak Easy Share camera. Fits
perfectly in my shirt pocket.
I use a condensor mic (tie-clip mic) and put it inside a Bose X headset that
and the intercom.
Yeah, sometimes I wish I would do something like you describe above,
but I like monday night quarterbacking my flights and listening to the
power changes and watching the strobing gives me insight on my power
management for my landings. I would lose that if I decided to tie
into my COMS.
on the glareshield?
I put it on the glareshield, but it's right at the very front, "wedged
in" with one of those leather portolio diddies that I have some charts
and approach plates in it for "weight". The straight edge of the
portfolio doesn't follow the curve of the wind screen so the camera
fits nicely in the moon shape gap between the portolio and windscreen.
The portfolio doesn't move at all and obviously during turbulent
days, the camera is secondary and wouldn't be up there. I tried
velcro, but the camera still gets a slight vibration, so I improvised
with the portfolio.
No, what ever came with the Kodak Easy share. It has 4x zoom
capability, but not good for "being in the flare" The camera is about
5 years old and like a timex, takes a licking and keeps on ticking.
I was told not to remove it. The prop was balance to .01 gram when I
had it balanced about 3 years ago, so I leave it. I was operating the
throttle while the guy was there doing his jig, and was absolutely
fascinating to watch. It took 2 hours of adjusting and getting it
balanced at various RPMS.
I don't know why your prop is so visable. Mine doesn't do this. It looks
Camera frame rate I believe is 30 fps and it doesn't have a frame rate
change in the menu options.
Tomorrow, keeping my fingers crossed, 600 foot ceilings so I will go
knock out some approaches. Just had avionics work done so need to put
it through it's paces. I ran it through it's paces on a VFR flight
but the only thing I didn't test was the glide slope, picked up a
localizer passing HKS on my way to Brookhaven, so I know I am good for
that and of course the VOR works nicely. GPS 430 good to go, just
have not done an ILS.
Had to get some shims. My audio panel wanted to slide out last week,
and I think the mount screw either broke or something sheared in the
back. So, I figure shim it on the top and bottom and I should be good
to go. I had a very bad experience with the shop and am doing
everything I can not to go back, but I sure won't pay another shop for
"warranty work" either.
Private email has additional questions not asked here :-)
Allen
Landing Brookhaven MS - Video [email protected] Piloting 0 September 4th 08 03:08 AM
Landing Tupelo MS - Video [email protected] Piloting 1 June 19th 08 03:48 PM
Landing Tupelo MS - Video [email protected] Instrument Flight Rules 0 June 14th 08 06:26 PM
Here is Some video Of Landing In My 150 7676U NW_PILOT Owning 17 July 9th 04 04:10 AM
Here is Some video Of Landing In My 150 7676U NW_PILOT Piloting 15 July 8th 04 10:09 PM
