"PENTAGON WORKING TO GIVE F-35 JSF NUCLEAR-STRIKE CAPABILITY"
Old May 5th 09, 12:27 AM posted to rec.aviation.military,sci.military.naval,rec.aviation.military.naval
hcobb
Default "PENTAGON WORKING TO GIVE F-35 JSF NUCLEAR-STRIKE CAPABILITY"
On May 3, 10:20 pm, frank wrote:
We'd have to break some arms control treaties to do it.
Well that's (along with President BHO's tight military budgets) what's
grounded the 2018 bomber.
http://www.aviationweek.com/aw/gener...hannel=defense
In fact, there were two key, inter-related issues that created the
bomber reassessment: adding a nuclear weapons carrying capability and
renewed Start arms control treaty negotiations with the Russians.
The fix is to make it nuclear capable, but not operationally nuclear
armed. In the sense that it's tested to be survivable on the nuclear
battleground, but not tested with carrying any actual nuclear weapons.
By taking the non-nuclear mission away from the Spirits it would
improve the nation's overall nuclear posture and we could go into the
next round of treaties and bargain away the nuclear capabilities of
the BONE and BUFF.
-HJC
  #43
Old May 5th 09, 12:36 AM posted to rec.aviation.military,sci.military.naval,rec.aviation.military.naval
Dan[_12_]
the BONE and BUFF.
-HJC
Egad, even in cobb world none of that makes sense.
Dan, U.S. Air Force, retired
  #44
Old May 5th 09, 03:08 AM posted to rec.aviation.military,sci.military.naval,rec.aviation.military.naval
BlackBeard
On May 4, 3:16*pm, wrote:
On Mon, 4 May 2009 13:27:39 -0700 (PDT), BlackBeard
On May 4, 1:05*pm, Ed Rasimus wrote:
2.) Disabuse yourself from the notion that a CV is any sort of easy
target. I spent a lot of years trying to successfully do just that in
exercises. It is damn close to impossible. Whoever attempts it will
suffer severe losses in the process and even then may not succeed.
Well, from the air or surface maybe... *
Well, no.
I've sat on many an SSN over the years. *They are tough to catch but
I've yet to meat the submariner that's 7 feet tall, bullet proof, and
immortal. *:-)
And I served in SSN's and we expended more green flares than I could
count. Confined to a small box, wearing a noisemaker, and still
scoring the big tonnage.
BB
  #45
Old May 5th 09, 03:12 AM posted to rec.aviation.military,sci.military.naval,rec.aviation.military.naval
BlackBeard
On May 4, 3:17*pm, wrote:
On Sun, 3 May 2009 22:20:20 -0700 (PDT), frank
Would this not mean that by presidential order they could be put back?
Which ones?
None. The decision to remove the tactical nukes from our Navy was a
unilateral one made by Bush the 1st and carried out by Cheney in
1992. It was NOT covered by the INF treaty which would be the closest
in relative weapon "size."
BB
  #46
Old May 5th 09, 02:03 PM posted to rec.aviation.military,sci.military.naval,rec.aviation.military.naval
On Mon, 4 May 2009 19:12:11 -0700 (PDT), BlackBeard
Which ones?
Didn't think so. Thanks for the confirmation.
  #47
Old May 6th 09, 05:23 AM posted to rec.aviation.military,sci.military.naval,rec.aviation.military.naval
Andrew Swallow[_2_]
Ken S. Tucker wrote:
[snip]
The US, Brits + more have had an armed presence in
Iraq (or around), since 1991, 18 years, in Afgh since
2001, 8 years. A lack of fortitude might be argued in
the way those conflicts were resolved.
The Arabs etc. remember the USA left Vietnam that choose
not to remember the Americans stayed longer than the
Iran-Iraq War.
Andrew Swallow
  #48
Old May 6th 09, 11:21 PM posted to rec.aviation.military,sci.military.naval,rec.aviation.military.naval
hcobb
Iran-Iraq War.
Andrew Swallow
They have a much closer example (in time and space) in Somalia.
-HJC
  #49
Old May 7th 09, 02:54 AM posted to rec.aviation.military,sci.military.naval,rec.aviation.military.naval
J[_2_]
Ed,
Were you ever successful? (To the extent you can say.)
Thanks . . . J
  #50
Old May 7th 09, 03:55 AM posted to rec.aviation.military,sci.military.naval,rec.aviation.military.naval
Ian B MacLure
frank wrote in
On Apr 29, 11:20*pm, Ian B MacLure wrote:
"dott.Piergiorgio" wrote
inn
Mike ha scritto:
Inside the Air Force - 4/24/2009
GENERAL: PENTAGON WORKING TO GIVE F-35 JSF NUCLEAR-STRIKE
CAPABILITY
The Defense Department and a handful of allies have launched an
effort to ensure the F-35 Joint Strike Fighter program is capable
of conducting the most devastating mission in modern warfare --
delivering a nuclear bomb.
Ugh.....
let's cross well the fingers, there's already a mess, and a -D
version, available to select few, has all the potential to sink the
entire program......
* * * * Why another version? It would simply be a Block X update
to
* * * * whatever was fielded. What after all is the difference be
tween
* * * * nuclear and non-nuclear capable aircraft? Basically some
form
* * * * of safety gear related to weapon fusing.
* * * * IBM
Its a bit more than that. Takes a lot of work to be nuclear certified.
It is however doable and the process is well understood.
IBM
"Pentagon Wants Kill Switch for Planes" Jim Logajan Piloting 24 June 16th 08 03:27 PM
Spinner strobing as a "Bird Strike Countermeasure" Jim Logajan Piloting 259 December 13th 07 05:43 AM
Spinner strobing as a "Bird Strike Countermeasure" Jim Logajan Home Built 212 December 13th 07 01:35 AM
"British trace missile in copter strike to Iran" Mike[_7_] Naval Aviation 8 March 10th 07 08:20 PM
"Pentagon Command Shuffle Rekindles Equity Debate" Mike Naval Aviation 1 January 26th 07 03:04 PM
