Go Back   Home » AviationBanter forum » rec.aviation newsgroups » General Aviation
Cessna 152 (proper) air/fuel ratio...
Old May 15th 12, 12:58 AM
dtvonly dtvonly is offline
Junior Member
First recorded activity by AviationBanter: Jul 2011
Default Cessna 152 (proper) air/fuel ratio...
Hi. I am a student pilot and have always done "proper" leaning per flight altitude. I should have asked this a long time ago but...anyway...when using the mixture control to get "optimum" RPM at altitude, what is the "optimum" air/fuel ratio ? 3:1, 4:1, etc...
Thank you.
Old May 19th 12, 05:23 PM posted to rec.aviation.misc
Panic[_4_]
"dtvonly" wrote in message ...
Thank you.
dtvonly
Unless you have a device that reads out your air/fuel ratio you should
probably just use the old method. At cruise altitude with power/speed
stable, just lean out the mixture control until the engine runs a little
rough and then push it back in about an inch.
Old May 20th 12, 06:36 AM posted to rec.aviation.misc
RST Engineering[_2_]
Varies with the engine, with the fuel atomizaion scheme, displacement,
etc, but most of us live with a 15:1 air fuel ratio as a starting
point.
On Mon, 14 May 2012 23:58:14 +0000, dtvonly
Thank you.
Old May 21st 12, 05:47 PM posted to rec.aviation.misc
Bug Dout
RST Engineering writes:
point.
By volume or by mass?
Anyone who has two shirts when someone has none is not a Christian.
~ Lenny Bruce
Cessna 172 fuel selector Ross Owning 12 December 1st 08 05:44 PM
Proper Torque for Fuel Fittings Steve Waltner Home Built 10 February 20th 05 12:46 AM
Cessna 172 Fuel Flowmeter? CVBreard Piloting 9 January 26th 05 07:00 AM
Proper yoke calibration Rans Simulators 0 December 1st 04 03:38 PM
Proper stall recovery technique Chris OCallaghan Soaring 0 February 2nd 04 10:33 PM
