Why publish a plate for an OTS approach?
Old May 27th 07, 11:20 PM posted to rec.aviation.ifr
Paul Tomblin
Default Why publish a plate for an OTS approach?
I'm just reading IFR Refresher, and it has a report on an accident that
happened after a King Air was cleared for an SDF approach at KSME.
According to the article, at the time the A/FD and NTAP listed the SDF as
"Out of Service (OTS) - Indefinitely", and had been for four years, but
the plate was still being published with no mention that the SDF was OTS.
Why the hell would they continue to publish an approach plate in a
situation like that?
Paul Tomblin http://blog.xcski.com/
Experience is that marvelous thing that enables you recognize a
mistake when you make it again. -- F. P. Jones
Old May 27th 07, 11:37 PM posted to rec.aviation.ifr
Roy Smith
There's probably less paperwork and red tape involved to just notam
something OTS than to get it revoked. "We don't have to make sense, we're
the FAA".
Old May 28th 07, 12:57 AM posted to rec.aviation.ifr
Mark Hansen
the FAA".
Hmmm, I wonder. When they pulled the NDB approach at KSAC (Sacramento
Executive), it just went away -no more plate.
Maybe they think the SDF approach mentioned by the OP may come back at
some point, so they don't want to completely remove it from the system?
Mark Hansen, PP-ASEL, Instrument Airplane, USUA Ultralight Pilot
Cal Aggie Flying Farmers
Sacramento, CA
Old May 28th 07, 03:22 PM posted to rec.aviation.ifr
FDC NOTAMS are the vehicle to communicate changes to approach
procedures. If a pilot is unaware of an FDC NOTAM which applies to
his destination chart, he has not done adequate preflight.
the FAA".
Old May 28th 07, 02:54 AM posted to rec.aviation.ifr
Bob Gardner
An instrument approach is, in effect, an act of Congress. Although they do
it through obscure references to Part 97, each approach must be published in
the Code of Federal Regulations and, as you might imagine, it literally
takes an act of Congress to revoke one. Jepp and NACO probably have some
kind of contractual obligation to publish all existing approaches.
Bob Gardner
"Paul Tomblin" wrote in message
Old May 28th 07, 03:10 PM posted to rec.aviation.ifr
Paul Tomblin
You'd think that it would be a small change of procedure and a huge
improvement in safety if they would at least overprint the procedure with
"NAVAID OTS" or something.
To iterate is human; to recurse, is divine.
Old May 28th 07, 05:17 PM posted to rec.aviation.ifr
Bob Gardner
I don't think that either Jepp or NACO has the authority to do modify an
approach plate.
Bob
in
Old May 28th 07, 05:20 PM posted to rec.aviation.ifr
Jose
I don't think that either Jepp or NACO has the authority to do modify an approach plate.
They don't have the authority to modify an approach =procedure=.
However, they can chart the procedure any way they want. Overprinting
the words "Probably OTS, check notams", while raising questions that
probably should be raised, would be within their authority.
Jose
There are two kinds of people in the world. Those that just want to
know what button to push, and those that want to know what happens when
they push the button.
Old June 16th 07, 02:58 PM posted to rec.aviation.ifr
What part of your butt did you pull that BS out of?
Congress has nothing to do with the federal register.
do it through obscure references to Part 97, each approach must be
published in the Code of Federal Regulations and, as you might imagine,
it literally takes an act of Congress to revoke one. Jepp and NACO
probably have some kind of contractual obligation to publish all
Bob Gardner
Jeppesen Approach Plate Downloads Vince Butkiewicz Piloting 0 June 25th 06 12:25 AM
How long does it take the FAA to publish an approach? Beech45Whiskey Instrument Flight Rules 8 July 24th 05 02:03 AM
Why is ADF or Radar Required on MFD ILS RWY 32 Approach Plate? S. Ramirez Instrument Flight Rules 17 April 2nd 04 11:13 AM
Briefing an approach plate, especially while flying Peter R. Instrument Flight Rules 17 March 13th 04 01:43 AM
Approach plate Hankal Instrument Flight Rules 4 October 2nd 03 07:31 PM
