Schumanized Wing?
I might be spelling this wrong but could someone fill me in as to the advantages and disadvantages to the Schumanized Wing?
Thanks, Walt |
Schumanized Wing?
On Nov 19, 10:36*pm, Walt Connelly Walt.Connelly.
wrote: I might be spelling this wrong but could someone fill me in as to the advantages and disadvantages to the Schumanized Wing? Thanks, Walt -- Walt Connelly Schueman did extensive tests and detirmined the lower wing surface was all turbulent at speeds above 70 knots on the H-301 Libelle. He modified the Huter (sp?) airfoil to make it more like a wortman with pointed, rather than round leading edge. He also changed the flap drive to make the ailerons follow the flaps throughout all flap movements. I did all this + wing fairings and Kestral canopy on my H-301. She would keep up with the ASW-20's. They'd outrun me, but then mark the next thermal, where I'd outclimb them because they had 40 gallons of water vs. my 25 gallons. Sweet ship right up till the day the SSA said we couldn't race above the manufactures published maximum weight......................and the H-301 is 660 max! Good by Libelle, you were a good old bird right up till the bureacrats gave us the Spring Surprise in 1981? Cheers, JJ |
Schumanized Wing?
On Nov 20, 1:36*am, Walt Connelly Walt.Connelly.
wrote: I might be spelling this wrong but could someone fill me in as to the advantages and disadvantages to the Schumanized Wing? Thanks, Walt -- Walt Connelly See http://www.betsybyars.com/guy/soarin.../72-modif.html for Wil Schuemann's description of the many modifications he made to his H-301. The biggest advantage of the Schuemannized wing is its drastically improved performance at high cruising speeds while giving up none of its climbing abilities. Disadvantages? The wings are a little heavier. And of course re-contouring the wings is no walk in the park, but if you like going faster than the other guy... Jack Wyman (Former owner of the "Schuebelle": it's now in the National Soaring Museum). |
Schumanized Wing?
the SSA said we couldn't race above the manufactures published maximum weight......................and the H-301 is 660 max! Good by Libelle, you were a good old bird right up till the bureacrats gave us the Spring Surprise in 1981? Cheers, JJ Speaking as a bureacrat, JJ, do you seriously think we should get rid of weight restrictions? I can't wait to see what the FAA says when some guy crashes while flying at 15 lbs/ft2... John Cochrane |
Schumanized Wing?
Speaking as a bureacrat, JJ, do you seriously think we should get rid of weight restrictions? I can't wait to see what the FAA says when some guy crashes while flying at 15 lbs/ft2... John Cochrane I objected to the way it was done, 2 months before the nats I was told my ship would not be allowed to compete. Carl Herold said there would be a "grandfather" provision to allow the H-301 to fly and then did nothing to implement it. Water under the bridge, JJ |
Schumanized Wing?
On Nov 22, 8:02*am, JJ Sinclair wrote:
Water under the bridge, JJ Or, out of the bags, right JJ? Steve Leonard |
Similar Threads | ||||
ASW-20A Left Wing or Inboard Wing Skin Needed | Coucked | Soaring | 0 | August 29th 10 02:43 PM |
Low wing landing, high wing taking off...oops | [email protected] | Piloting | 1 | May 16th 08 09:41 PM |
Soft field landings - low wing vs high wing aircraft | Justin Gombos | Piloting | 19 | May 23rd 07 05:21 AM |
Books on Military Rotary Wing to Civilian Fixed Wing Transition? | Greg Copeland | Piloting | 5 | May 2nd 07 03:23 AM |
Mylar tape wing seals - effect on wing performance | Simon Waddell | Soaring | 8 | January 1st 04 03:46 PM |
