Cessna 172N with 0-320-H2AD
I am looking for an a/c, my first, to complete my training and to use
for recreational flying. I am looking at 172s and a book I recently acquired (The Cessna 172 by Bill Clarke) suggests that this engine is to be avoided. I saw an ad in Trade-A-Plane by Factory Engines and the prices for factory remanufactured engines are as follows: O-320-E2D - $16,652 (this engine is the predecessor to the H2AD) O-320-H2AD - $19,301 (the engine in question) O-320-D2J - $16,923 (the sucessor to the H2AD) To me this is indicative of continuing problems. What has been the expierience of owners of Cessna 172Ns with this engine? Paul |
Paul wrote:
What has been the expierience of owners of Cessna 172Ns with this engine? That they'd really like an 0-360 with 180+ hp... ;-) Extra ponies just make it fly like it should have, all along... |
This engine has a reputation for eating lifters and camshafts. We lost two
lifters and a camshaft at 1033 hours after purchasing a factory overhauled engine and spent ten grand having the engine rebuilt. That really, really, hurt. I did an extensive amount of research on the lifter issue and set up a web site to collect information. Here is what I concluded: The early lifter problems that this engine had are not the same as it currently experiences. Other engines have lifter problems but lifter and cam failures are significantly under reported in them. Lifter and camshaft damage can progress to a startling extent before effecting performance. The performance loss is so slow that pilots don't notice. The H2AD has an AD that requires a check for metal that is optional on other engines. A great feature of this engine is that the lifters can be pulled and inspected easily. Therefore, when lifters spall, the problem is more likely to be discovered. Other engines just go along quietly making metal and wearing away their camshafts. Most take their worn camshafts to the overhaul shop. A few fracture lifters or break cam shafts and stop running. There were rampant metallurgical problems with lifters in the late 90's due to the move to offshore outsourcing and labor/management upheavals. The FAA will be coming out with a document about lifter problems late this year. If you own one of these engines, you should have the lifters pulled and inspected every second oil change. This will add about $2000 to the life cycle cost of the engine but detecting a failing lifter early may save removing your engine to split the case and replace a $3000 camshaft. You should also probably put new lifters in about mid life which will add another $1000 to the life cycle cost. DO NOT buy a used O-320 H2AD, or any engine for that matter, without a lifter and camshaft inspection. This will only take a couple hours with the H2AD whereas other engines will need to have some cylinders pulled. Make preheat your religion. Saying, "Just this once won't hurt." Can make that $100 hamburger a $10,000 hamburger. We use an electric oil pan heater, cowl blanket, and cowl plugs. Air head, for the length of time most FBO's will run the heater, doesn't get the oil warm enough. If you see a single flake of metal in your oil filter that sticks to a magnet, especially if it is smooth on one side, PULL THE LIFTERS! Don't let the A&P tell you that all mid life engines make some metal and you shouldn't worry until it gets to a quarter teaspoon or so. That advice probably cost us $10,000. After the first pinhead size piece comes out of a lifter, the whole face come apart very fast and starts damaging the camshaft. Don't fly the plane until the lifters are looked at. There is a lot to like about this engine. It sends about twice as much oil to the heads as other Lycomings and has a giant oil cooler. It runs very cool and is not prone to valve problems. Our engine runs very well between peak and 25 degrees LOP. All engines of this class are prone to plug fouling so running very lean, even at the expense of a hint of roughness, is important. For more, read: http://baldeagleflyingclub.org/Manual.htm The dual mag is delicate. Have it thoroughly inspected and adjusted every 500 hours, more often if anything in the engine performance changes. A good reason for running very lean is that any problems such as induction leaks or ignition adjustment drift show right up. Running ROP covers up a lot of sins. Every engine has its issues. This one may be somewhat more troublesome but that is counter balanced by the ease of managing them. I've seen plenty of spalled lifters in engines with mushroom lifters. It that case, you are committed to an engine teardown. With the O-320 H2AD, it's only a two hour job if you catch it before the camshaft is damaged. It's a good engine for a plane flow by a lot of pilots because it is quite hard to overheat the heads. -- Roger Long "Paul" wrote in message m... I am looking for an a/c, my first, to complete my training and to use for recreational flying. I am looking at 172s and a book I recently acquired (The Cessna 172 by Bill Clarke) suggests that this engine is to be avoided. I saw an ad in Trade-A-Plane by Factory Engines and the prices for factory remanufactured engines are as follows: O-320-E2D - $16,652 (this engine is the predecessor to the H2AD) O-320-H2AD - $19,301 (the engine in question) O-320-D2J - $16,923 (the sucessor to the H2AD) To me this is indicative of continuing problems. What has been the expierience of owners of Cessna 172Ns with this engine? Paul |
I am not sure where to start with posting this request for advice. However on reading through your post I thought you may have received some worth while advice even though you initial posting was in 2004.
I have recently purchased a Cessna 172N with the 0-320-H2AD motor and it does not have the performance of my other C172 fitted with the 0-320-2ED motor. My question is it the 'H" motor that is causing this lack of performance and if it is, is it worth changing it to the 2ED motor?? Quote:
Quote:
Quote:
There's no problem with the ad you saw. The ad will help you on what you are looking. I think there is other option on that ad, right? |
Similar Threads | ||||
1/72 Cessna 300, 400 series scale models | Ale | Owning | 3 | October 22nd 13 03:40 PM |
FS: 1979 Cessna 172N, Worcester MA | Dwight Ernest | Aviation Marketplace | 0 | April 6th 04 03:59 PM |
FORSALE: HARD TO FIND CESSNA PARTS! | Enea Grande | Aviation Marketplace | 1 | November 4th 03 12:57 AM |
FORSALE: HARD TO FIND CESSNA PARTS! | Enea Grande | Owning | 1 | November 4th 03 12:57 AM |
USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 03:17 PM |
