Best performing Vario?
Old February 21st 13, 01:03 AM posted to rec.aviation.soaring
SoaringXCellence
Default Best performing Vario?
On Thursday, February 14, 2013 4:24:54 PM UTC-8, Bill D wrote:
On Thursday, February 14, 2013 3:19:21 PM UTC-7, Kimmo Hytoenen wrote:
After Argentina some competition pilots were quite disappointed
with the new variometers using acceleration to calculate lift. I
have not tested myself, just telling their opinion.
At 21:49 14 February 2013, John Galloway wrote:
If the butterfly -- or clearnav, with future software -- did
read
out 3 d
w=
ind 20 times a second, this would be a big advantage. Not
only could you
de=
tect lift long before F =3D MA gets the glider moving upward,
you could
tel=
l upward gusts from forward gusts and sideways gusts.
Dynamic soaring
might=
even become possible, or at least better energy extraction
from gusts.
Eve=
n the 302 has the necessary sensors, my impression is that
we're all
waitin=
g on the software development.=20
John Cochrane
Regarding gusts, the Butterfly website (in FAQ) already claims:
"A conventional variometer uses changes in air pressure (TE-
pressure, static- and total-pressure) to determine energy
changes the aircraft experiences. Butterfly Vario does the
same.
Additionally it uses an inertial sensing platform that allows for
real-time determination of airmass-movement and realtime
determination of wind. With this technology a pilot can judge
the difference between gust induced energy changes and
thermal induced energy changes."
John Galloway
Not sure, but I suspect they are mixing frames of reference. In theory, the way to do this is solve the TE equations in the inertial and air-data domains separately then compare them. A gust will show up strongly in the air-data but less so in the inertial data so a computer - or a pilot - can tell the difference.
A purely inertial vario will require a full IMU with GPS updating. These things are probably still too expensive for sailplanes but only just.
If we have some EE guys here, SparkFun electronics offers several IMU sensor system under $150: https://www.sparkfun.com/categories/160
  #142
Old February 21st 13, 01:04 AM posted to rec.aviation.soaring
SoaringXCellence
read
out 3 d
w=
only could you
de=
you could
tel=
Dynamic soaring
might=
from gusts.
Eve=
we're all
waitin=
John Cochrane
same.
John Galloway
Sparkfun has several IMU systems under $150: https://www.sparkfun.com/categories/160
  #143
Old February 21st 13, 02:26 AM posted to rec.aviation.soaring
JS
To me the best vario would have audio the pilot can really relate to. This allows adjustments to thermal turns to be consciously made by the idiot behind the stick, while looking at the display usually marketed by Mecaplex.
WTB: 57mm Cambridge Vario/FS: 80mm Cambridge Vario ufmechanic Soaring 0 March 24th 09 05:31 PM
Martin Mars, Performing Live In Downtown Vancouver! Zomby Woof Aviation Photos 3 January 20th 08 03:10 PM
Martin Mars, Performing Live In Downtown Vancouver! Zomby Woof Naval Aviation 2 January 11th 08 06:10 PM
Navy Performing Well, Keeps Eye on Future Force Otis Willie Naval Aviation 0 February 14th 05 10:06 PM
AN-2 performing a loop Maro_SK Aerobatics 1 March 25th 04 08:18 PM
