Securing an oxygen bottle
Old October 17th 19, 08:11 PM posted to rec.aviation.soaring
Ian Kennedy
Default Securing an oxygen bottle
To save re-inventing the wheel, whats the best way of securing the oxygen
bottle within its fitting in an LS3?
Any suggestions welcome.
TIA
Ian K
Old October 17th 19, 10:19 PM posted to rec.aviation.soaring
JS[_5_]
TIA
Ian K
The LS3 and 4 had a clamp which screwed into the bulkhead and used a bolt to hold the E or AL682 cylinder in place.
Don't know if the Aerox cylinder bracket (available online) will fit.
If you don't have abracket, a swaged wire rope loop around the neck of the cylinder and a "maillon rapide" (quick link) or similar to attach it to a forged eyebolt through the bulkhead works well. Best to either use coated wire or sleeve it with instrument tubing.
Old October 18th 19, 11:21 AM posted to rec.aviation.soaring
Ian Kennedy
oxygen
TIA
Ian K
t=
f=
wi=
Thanks, thats a good idea.
Cheers
Ian K
Old October 20th 19, 02:54 AM posted to rec.aviation.soaring
George Haeh
Don't do this:
* Foam wrapped around cylinder held on with two zip ties.
* Two more zip ties through said zip ties and eyebolts through 3/16" plywood hinged on other side.
Oxygen bottle for ASW 27 and ASG 29 [email protected] Soaring 8 April 18th 16 04:08 PM
Oxygen Bottle Roger Fowler[_2_] Soaring 2 November 19th 11 09:17 PM
oxygen bottle No Name Piloting 2 May 23rd 07 07:09 AM
Securing portable oxygen dutch Instrument Flight Rules 4 February 10th 04 05:30 AM
Securing portable oxygen dutch Owning 3 February 10th 04 05:30 AM
