Some LiFePO4 Battery Testing Results Manual and Automated
Old October 20th 19, 05:14 AM posted to rec.aviation.soaring
John DeRosa OHM Ω http://aviation.derosaweb.net
Default Some LiFePO4 Battery Testing Results Manual and Automated
T8,
Thanks for the data point. To compare apples to apples it would be interesting to test connected to a 12ohm load as I did - not that 12ohms (~1A) is somehow perfection.
Thanks, John OHM
  #32
Old October 20th 19, 02:33 PM posted to rec.aviation.soaring
Mike N.
Just a suggestion but you might want to look at the following.
https://www.skyrc.com/BD200
Allows you to set discharge current and cut off voltage. Displays consumed mAh over discharge period.
You do have to calculate the cut off voltage per battery type X cells in series. There are many articles (and debates) on safe dishcharge cutoff voltages for various lithium batteries chemistries on line so I am not going to make a suggestion as to cut off voltage.
I just wanted to suggest the above tool as I find it useful. I fly very large scale R.C. helicopters which use rather large battery packs at high discharge currents and I find the above very useful for analyzing my packs.
YMMV
  #33
Old October 20th 19, 03:26 PM posted to rec.aviation.soaring
Tango Eight
The only reason for selecting 400 mA discharge is that is as much current as my little Imax RC battery charger can sink.
400mA vs 1 A is not quite apples/apples, agreed, but for LFP batteries it's going to be very close.
T8
Test results LiFePO4 glider batteries after 6 years SF Soaring 102 August 9th 18 06:46 PM
Resetting a Bienno LiFePO4 Battery OHM Ω http://aviation.derosaweb.net Soaring 3 June 26th 18 09:26 PM
LiFePO4 battery technolocy [email protected] Soaring 9 October 17th 12 10:05 PM
LiFePO4 battery ASM Soaring 4 December 6th 11 07:00 PM
Spring Cleaning and Battery Testing ContestID67[_2_] Soaring 34 March 20th 11 06:49 PM
