Howling sound when flying
  #25
Old October 20th 19, 09:33 PM posted to rec.aviation.soaring
Armand Charbonneau
Default Howling sound when flying
On Sunday, October 20, 2019 at 2:22:57 PM UTC-6, wrote:
Hi Armand,
there usually is a rubber seal at the opening of the elevator pushrod. This should be available from the factory in case it is missing on your ship. We installed V-Tape to cover the canopy front and aft canopy gaps of our Ventus 2cM. This reduced cockpit noise significantly. You will have to heat it up a bit in order to make it fit to the curvature of the canopy frame.
I once had straws in the front vent of my LS8. It was quiet, but they significantly reduced the airflow through the vent. A piece of fur did the same job without hindering the airflow.
Best
Christoph
The rubber seal is in place and seemingly good condition. I will try the V-tape and fur suggestions. Thanks.
Howling noise from nose vent toad Soaring 9 February 23rd 09 02:23 PM
What a sight...and what a sound Roger (K8RI) Piloting 15 July 4th 07 03:53 PM
What a sight...and sound. Roger (K8RI) Piloting 1 July 2nd 07 01:11 PM
What is this sound? gatt Piloting 14 June 9th 04 04:37 AM
F-86 and sound barrier VH Military Aviation 43 September 26th 03 02:53 AM
Copyright 2004-2025 AviationBanter.
