Garmin 430 VOR reception
Old September 29th 04, 02:26 PM
Maik
Default Garmin 430 VOR reception
Hi!
I have a SL30 and a GNS 430 in my plane. They use the same antenna via a
splitter.
When I dial in the same VOR in both units the SL30 catches up the
radials always between 20 and 50 nautical miles earlier than the GNS
430! (Altitude about 3000 ft, flat area)
Is this normal?
What is your experience?
How far away do you have a reception of a VOR with your GNS 430?
Fly safe!
Maik
Old September 29th 04, 02:49 PM
Rich
I can't speak for the GNS 430, but the SL30 has UNBELIEVEABLE signal
processing capability. I can track a good VOR well over 100 miles, and
I've got a mediocre cats whisker antenna mounted on my tail. I'm told
the SL30 uses digital signal processing; I don't know what the GNS 430 uses.
In short, I'm not at all surprised by your experience.
Rich
Maik wrote:
Hi!
splitter.
Is this normal?
Fly safe!
Maik
Old September 29th 04, 04:56 PM
john smith
It would seem that UPS-AT technology is significantly better than Garmin's.
Rich
Maik wrote:
Hi!
a splitter.
Is this normal?
Fly safe!
Maik
Old September 29th 04, 05:14 PM
uses.
VOR reception range is dominantly determined by line-of-sight. However, in
marginal situations (i.e. the station is just over the horizon) receiver
quality and/or antenna cable loss can make a significant difference. I do
not know if he VOR processing system in the GNS 430 is similar to the one
used in the SL30, however a simpler explanation for the difference could be
different RF losses in the cables from the splitter to the receiver. By the
way, a VOR test system could quantify the sensitivity difference very
quickly with a simple over-the-air test.
-Elliott Drucker
Old September 29th 04, 09:30 PM
Dean Wilkinson
The VOR signal out of the receiver is a 9960Hz sine wave that is AM
modulated at 30Hz and FM modulated at 30Hz. The phase difference
between the AM and FM signals is the bearing to the station.
Outside of the standard service volume of a VOR, this signal starts to
get quite noisy. This makes domodulating the AM and FM components
more difficult as the signal to noise ratio degrades. The quality of
the filtering of the 30Hz and 9960Hz bandpass filters (or equivalent
digital bandpass filters in a DSP) determines how far out you can
accurately receive the station. Apparently the SL30 does a better job
of filtering out the noise than the GNS430.
Dean
Maik wrote in message ...
Hi!
splitter.
Is this normal?
Fly safe!
Maik
Old September 30th 04, 03:48 AM
DP
I wouldn't be satisfied with the answer that one unit is more sensitive or
has better demod until I knew that the splitter, connectors, and coax were
all in good shape. Then I'd wonder if the Garmin was detuned somehow instead
of jumping right on poor or lesser design.
Dan
Old September 30th 04, 02:45 PM
Dean Wilkinson
All he has to due is swap coax cables between the units to find out...
"DP" wrote in message news:kuK6d.69$lf2.60@trnddc09...
Dan
Old September 30th 04, 03:49 PM
Jack McAdams
Hi!
splitter.
Is this normal?
Fly safe!
Maik
You may want to try swapping the coax leads at the splitter. That
would quickly tell you if you had any splitter / connection / coax
issues.
Jack
Garmin 296 worth the money? Terry Owning 15 June 22nd 04 09:03 AM
Garmin Specials ADV Michael Coates Home Built 0 March 18th 04 12:24 AM
Garmin DME arc weidnress Dave Touretzky Instrument Flight Rules 5 October 2nd 03 02:04 AM
"Stand Alone" Boxes (Garmin 430) - Sole means of navigation - legal? Richard Instrument Flight Rules 20 September 30th 03 02:13 PM
Garmin 430/530 Questions Steve Coleman Instrument Flight Rules 16 August 28th 03 09:04 PM
