Trig TA-70 antenna installation
Old December 30th 18, 04:12 PM posted to rec.aviation.soaring
Default Trig TA-70 antenna installation
Planning to install Trig TT-22 transponder with ADSB -out to my experimental glider.
Trig manual saying that TA 70 GPS is a permanently mounted external antenna. Where is recommended place of installation on gliders? Does anyone installed antenna inside glider fuselage?
p.
Old December 30th 18, 04:19 PM posted to rec.aviation.soaring
Richard Pfiffner[_2_]
p.
Why are you installing a TA70 in an experimental glider?
See capabilities of TN72 with a smaller internal antenna and TA70 on this page
http://www.craggyaero.com/transponder.htm
Richard
www.craggyaero.com
Old December 30th 18, 04:39 PM posted to rec.aviation.soaring
Even on your website it says TA-70 recommended. But if a small $49 GPS antenna will work just fine I will try it that way. p
Old December 31st 18, 12:34 AM posted to rec.aviation.soaring
Dan Marotta
The GPS antenna for my TA70 was installed in the turtle deck area of my
Stemme.Â* An aluminum shelf was fabricated upon which to mount the
antenna.Â* It passed inspection and flight test and I got the $500 rebate
from the FAA.
p.
Dan, 5J
Trig TN72 Antenna Andrew Ainslie Soaring 17 April 6th 17 04:21 AM
ASW 27 or 27-18 406 ELT & antenna installation chipsoars Soaring 6 October 10th 09 04:07 PM
Antenna installation question [email protected] Soaring 6 February 28th 08 02:14 PM
Antenna Installation on Longez Glennbob Home Built 11 May 21st 07 03:03 AM
FLARM antenna installation Kevin Neave Soaring 5 January 16th 07 06:53 PM
