Burning oil
Old March 10th 15, 07:41 PM posted to rec.aviation.piloting
Dallas
Default Burning oil
Why do reciprocal engines burn so much oil?
I've always wanted to know...
Dallas THE AGMSFS GROUP HAS MOVED AWAY TO:
http://forums.delphiforums.com/flightsimulator/start
Old March 11th 15, 06:58 AM posted to rec.aviation.piloting
Larry Dighera
Default Burning oil
My understanding is that the increased clearance between cylinders and pistons
required to accommodate the thermal expansion of air-cooled IC engines results
in excessive oil consumption. But I'm no certified mechanic...
On Tue, 10 Mar 2015 19:41:43 +0000 (UTC), Dallas
Old March 11th 15, 08:45 PM posted to rec.aviation.piloting
george152
Default Burning oil
And then there's the dry sumps systems
Old March 14th 15, 05:09 PM posted to rec.aviation.piloting
Dallas
Default Burning oil
Sounds pretty reasonable to me.
Old March 20th 15, 10:31 PM posted to rec.aviation.piloting
Brian Whatcott
Default Burning oil
It's mostly air-cooled recips that burn the oil.
The temp range experienced by an air cooled cylinder is large; the
piston is aluminum alloy, the cylinder steel.
Aluminum expands more with temperature than steel, so a sufficient gap
between piston and cylinder is needed when cool to avoid jamming when hot.
Brian Whatcott Altus OK
Old March 22nd 15, 05:27 AM posted to rec.aviation.piloting
Dallas
Default Burning oil
Brian Whatcott wrote:
The temp range experienced by an air cooled cylinder is large; the piston
Thanks for confirming.
Dallas
Putting around burning av gas ColSteve Piloting 11 December 18th 08 02:53 PM
Berk and Burning Man in Air and Space Gatt Piloting 3 July 19th 07 05:08 PM
flying to Burning Man Sylvain Piloting 19 November 15th 06 02:49 AM
"what's burning?" 569 Piloting 16 December 22nd 04 03:05 AM
Burning Question (737) Zomby Woof General Aviation 12 October 18th 03 08:42 PM
