Engine stumble folowup
Old December 10th 05, 05:26 PM posted to rec.aviation.piloting
Default Engine stumble folowup
OK..
By "feel" there is a little looseness in the throttle valve
bushings in the carb.. we gona look further.
Thanks to all for some great thoughts/solutions.
Can anybody suggest some tests to confirm an intake system
leak that allows excess low DA air to lean the mix when the throttle
valve closes rapidly at high engine RPM?
What clearance should there be in the Throttle Valve bushings?
(if any)
Dave
Old December 11th 05, 02:38 AM posted to rec.aviation.piloting
Arrrrughhh!
Flew today, -5C as opposed to -8C...
Could not get it to stumble on throt retard.. Rich, lean, VERY lean,
Rt tank,Lt tank, Pump on/off.
I don't know whether to be disappointed or elated.
Looks like I gotta fly it some more...
Dave
On Sat, 10 Dec 2005 13:26:29 -0400, Dave
OK..
(if any)
Dave
Old December 13th 05, 05:46 AM posted to rec.aviation.piloting
Dave,
There should NOT be any perceivable movement (side-to-side) in the
throttle shaft whatsoever, IDEALLY!
Best way to test for intake leaks is to use some sort of carb spray or
possibly WD-40. Lokk ofr a decrease in engine speed or stumbling ...
while on the ground, of course!
Have fun!
Dave wrote:
Arrrrughhh!
Dave
OK..
(if any)
Dave
Engine stumble, Thoughts? Dave Piloting 16 December 6th 05 04:18 AM
Engine Balancing and Resonance Vibration Problem AllanFuller Owning 13 September 12th 05 12:51 AM
What if the germans... Charles Gray Military Aviation 119 January 26th 04 11:20 PM
Real stats on engine failures? Captain Wubba Piloting 127 December 8th 03 04:09 PM
