Bioenno Power LiFePO4 12V Glider Batteries
Old April 16th 15, 06:27 AM posted to rec.aviation.soaring
Paul Remde
Default Bioenno Power LiFePO4 12V Glider Batteries
Hi,
I just added some new batteries to my web site tonight. They have been
highly recommended to me by several sailplane pilots.
New - Bioenno Power Lithium Iron Phosphate LiFePO4 12V Glider Batteries
- Enhanced cycle life - up to 2000 charge cycles! After 2000 charge cycles,
the battery still holds 75-80% of its original capacity.
- Lower weight - less than half the weight of lead-acid batteries! If you
are accustomed to using lead-acid batteries - you will be shocked the first
time you pick-up one of these batteries.
- Constant and stable discharge voltage - Lead-acid batteries gradually lose
voltage over time as they discharge - dropping below 12V early-on. LiFePO4
batteries have a much more gradual decrease in voltage until they are nearly
fully discharged - staying at 13+V for most of their discharge cycle - so
they are able to power your sailplane radio and instruments at higher
voltages for longer periods of time. Higher voltages assure maximum transmit
power from radios and transponders.
http://www.cumulus-soaring.com/bioenno.htm
Best Regards,
Paul Remde
Cumulus Soaring, Inc.
Old April 16th 15, 04:04 PM posted to rec.aviation.soaring
Dan Marotta
A comment on lithium batteries since I have two in my glider and a
digital volt meter mounted on the panel... I don't notice much voltage
drop as I did with lead batteries other than when I transmit. The data
available for the batteries indicates a rapid decline and shutoff when
the battery is nearly spent. I don't think that's a problem since the
shutoff voltage is around 9.6 volts and your radio will quit
transmitting before reaching that limit.
The reason I post this is because I was using a lithium powered
flashlight the other day while working on my car and, when the battery
reached it's limit, it simply shut off. It was so sudden that I thought
the bulb had burned out. No dimming as you're used to with standard
batteries. Changing the bulb had no effect so I swapped batteries with
my drill and the light worked again. Charging the battery took less than
an hour.
On 4/15/2015 11:27 PM, Paul Remde wrote:
Hi,
been highly recommended to me by several sailplane pilots.
cycles, the battery still holds 75-80% of its original capacity.
you are accustomed to using lead-acid batteries - you will be shocked
the first time you pick-up one of these batteries.
gradually lose voltage over time as they discharge - dropping below
12V early-on. LiFePO4 batteries have a much more gradual decrease in
voltage until they are nearly fully discharged - staying at 13+V for
most of their discharge cycle - so they are able to power your
sailplane radio and instruments at higher voltages for longer periods
of time. Higher voltages assure maximum transmit power from radios and
transponders.
Best Regards,
Paul Remde
Dan Marotta
Old April 16th 15, 04:29 PM posted to rec.aviation.soaring
jfitch
digital volt meter mounted on the panel...* I don't notice much
voltage drop as I did with lead batteries other than when I
transmit.* The data available for the batteries indicates a rapid
decline and shutoff when the battery is nearly spent.* I don't think
that's a problem since the shutoff voltage is around 9.6 volts and
your radio will quit transmitting before reaching that limit.
battery reached it's limit, it simply shut off.* It was so sudden
that I thought the bulb had burned out.* No dimming as you're used
to with standard batteries.* Changing the bulb had no effect so I
swapped batteries with my drill and the light worked again.*
Charging the battery took less than an hour.
Hi,
I just added some new batteries to my web site tonight.* They have
Batteries
charge cycles, the battery still holds 75-80% of its original
capacity.
If you are accustomed to using lead-acid batteries - you will be
shocked the first time you pick-up one of these batteries.
below 12V early-on. LiFePO4 batteries have a much more gradual
decrease in voltage until they are nearly fully discharged -
staying at 13+V for most of their discharge cycle - so they are
maximum transmit power from radios and transponders.
Best Regards,
Paul Remde
Dan Marotta
I was wondering about this characteristic myself, but don't! I bought a Stark Power LiFePo4 battery and ran it until it was discharged. The voltage declined very slowly over the first 8 hours or so, then more rapidly over about the next 2 hours before I shut it off at 11.9 V. This led me to conclude that a) mine will last for a very long flight and b) the decline in voltage gives plenty of warning that it is near the end.
Old April 16th 15, 10:08 PM posted to rec.aviation.soaring
Before we decided to sell the Stark Power LiFePo4 battery, we installed two of them in our DUO Discus. The DUO has lots of electronics in both cockpits including a transponder, Flarm, flight computers, etc, etc.
We flew on one battery for two long days, just to see how long they might last, and it still had lots of power left. We obviously now have both installed, and connected as we did with the previous batteries.
We have sold a couple hundred of these with no complaints or problems, and they seem to be lower cost than others I am aware of. Even the important battery charger is reasonable in cost. They charge very quickly.
At this time, we do not suggest using them for high power applications such as used in self-launch gliders.
Tom Knauff
www.eglider.org
Old April 17th 15, 01:47 AM posted to rec.aviation.soaring
Richard[_9_]
Tom Knauff
www.eglider.org
I flew with the Stark Power Batteries for a flying season before I started selling them. Also did some tests with Electrofly charger battery discharger see results:
http://www.craggyaero.com/lifepo_battery.htm
Richard
www.craggyaero.com
Old April 19th 15, 06:22 AM posted to rec.aviation.soaring
[email protected][_1_]
Tom:
I am curious how you have two batteries wired in the DUO? Parallel, two switches to a common bus?
Inquiring minds want to know!
Thanks
Old April 19th 15, 03:37 PM posted to rec.aviation.soaring
Dan Marotta
Not Tom, but I have two LiFePO4 batteries with two toggle switches wired
to a common DC bus. Switchover is simple: raise the second switch,
lower the first.
On 4/18/2015 11:22 PM, wrote:
Tom:
Thanks
Dan Marotta
Old April 20th 15, 02:51 AM posted to rec.aviation.soaring
Thanks, Dan. There seems to be a plethora of over-thinking on this subject, but I could be wrong......
Old April 20th 15, 12:48 PM posted to rec.aviation.soaring
Martin Gregorie[_5_]
A little searching on RS, Farnells, and similar outlets will find break-
before-make changeover switches. If the momentary voltage drop as you
throw the switch causes problems, put a decently sized capacitor
(1000-2000 microfarad) across the output lines of the switch with a small
resistor 10-15 ohms) in series with it. The resistor may be unnecessary:
its mainly there to limit to power surge to about 1A when the battery is
connected and, as the panel only draws around 400mA with everything on,
is too small to cause a significant voltage drop while the switch is open
circuit.
The season before last I discovered that, if I kicked the XLR plug
feeding power to my panel when I was getting in, the momentary power drop
would switch my radio and main vario off Putting a 2000 microfarad
capacitoy and 10 ohm resistor across the panel side of the plug has been
a permanent cure.
I've watched it with a voltmeter across the panel side: it takes about a
second for the voltage to drop to zero when the battery is disconnected,
so the momentary disconnection if I kick the plug isn't nearly long
enough to drain the capacitor.
martin@ | Martin Gregorie
gregorie. | Essex, UK
org |
Old April 20th 15, 04:42 PM posted to rec.aviation.soaring
On Mon, 20 Apr 2015 11:48:46 +0000, Martin Gregorie wrote:
I see I left a badly edited mess, so here is another try:
Another way of solving the battery switching problem is to use a break-
before-make change-over switch. These are often rotary switches.
suitable switches for 12 volts at the sort of currents we require.
small resistor (10-15 ohms) in series with it. The resistor may be
unnecessary: its mainly there to limit to power surge to about 1A when
the battery is connected.
feeding power to my panel when I was getting into my cockpit, the
resulting momentary power glitch would switch my radio and main vario off,
which was annoying. Putting a 2000 microfarad capacitor and 10 ohm
resistor across the panel side of the plug has been a permanent cure.
My panel only draws around 400mA with everything on so, even with the
resistor in circuit, the capacitor is able to supply enough voltage and
current to keep the panel alive over the short period while the
connection in the plug is lost: with the capacitor charged to 12v the 10
ohm resistor limits current to 1200 mA. As this is three times more than
the panel requires, it won't affect the operation of any instruments
while the capacitor is powering them.
To check this I put a voltmeter across the panel side of the connector
and, with a stable 12v shown, disconnected the battery. It took about a
second for the voltage to drop to zero. In other words the momentary
disconnection if I kick the plug isn't nearly long enough to drain the
capacitor and cause anything to switch off.
org |
K2 vs. StarkPower LiFePo4 batteries Fox Two[_2_] Soaring 36 April 16th 15 05:14 PM
LiFePO4 Batteries vontresc Soaring 56 June 27th 14 07:25 PM
Experience with StarkPower LIFEPo4 Batteries? Papa3[_2_] Soaring 15 May 7th 13 07:17 PM
LiFePO4 batteries JS Soaring 26 October 15th 12 02:51 PM
Glider Batteries and Chargers Grider Pirate Soaring 29 September 1st 10 05:52 AM
