Question: DP altitude vs MCA/MEA
Old April 6th 04, 03:41 AM
Doug Easton
Default Question: DP altitude vs MCA/MEA
Here's a question for the group from a low time ifr pilot...
The HASSA4 DP out of Ontario, CA specifies a minimum climb gradient that
would take you over the POM vor at 4400ft and then out V197 to the PMD vor.
The MCA for the POM vor nw bound on V197 is 8300ft and the MEA for that
segment is 10000ft. So can I fly the DP with the given climb gradient or am
I going to have to climb in hold at the POM vor?
Thanks
Old April 6th 04, 01:09 PM
Thanks
The climb gradient assumptions used for airways are much more shallow than even
the minimum DP climb gradient when constructing MCAs. When flying the DP you
comply with the requirements of the DP. You are not in the en route/Victor
Airway environment until you complete the DP.
Old April 6th 04, 01:31 PM
Ron Rosenfeld
On Tue, 06 Apr 2004 02:41:40 GMT, "Doug Easton"
Thanks
If you were required to climb in a hold at POM, it should have been so
stated in the DP. There is a restriction to climb at 350/375 ft per NM to
9,000 feet. So long as you do that, and then continue to climb at the
standard rate for the altitude above 9,000', you are assured obstacle
clearance.
Note that there is a restriction to cross POM at or *below* 9,000', an
"expect filed altitude" 10 minutes after departure.
Also, be sure to check winds aloft which may impact your climb rate.
In looking at the charts for that area, I see that the southbound MEA on
V197 is only 6400', and the MEA's south of POM are under 5,000', so I
suspect that the climb rate has been calculated to allow you to clear all
obstacles, and there is not an error in the procedure.
Old April 6th 04, 02:05 PM
Roy Smith
To pick a nit in an otherwise good answer, winds will not affect your
climb rate, just your climb gradient.
Old April 6th 04, 03:24 PM
True, unless the winds aloft cause a downdraft.
Old April 6th 04, 06:46 PM
Ron Rosenfeld
You're correct. And the "climb" noted on the NACO charts is more properly
called "climb gradient" on the Jepp charts.
Old April 7th 04, 03:10 AM
kage
On a "victor" airway, the climb gradient that must be made is 150 ft/nm
below 5000'.
120 ft/nm between 5000 and 10,000ft.
100 ft/nm above 10,000.
UNLESS there are charted restrictions.
Karl
CFII mode
Old April 7th 04, 03:29 AM
below 5000'.
Not exactly. Those values are correct, but any charted restriction will be
an MCA, not an increase in those gradients, unlike DPs.
A question on Airworthiness Inspection Dave S Home Built 1 August 10th 04 05:07 AM
Say Altitude. Hankal Instrument Flight Rules 26 April 8th 04 07:01 AM
Question about Question 4488 [email protected] Instrument Flight Rules 3 October 27th 03 01:26 AM
GPS Altitude with WAAS Phil Verghese Instrument Flight Rules 42 October 5th 03 12:39 AM
