rotax carb
Old May 15th 20, 04:34 PM posted to rec.aviation.soaring
john firth
Default rotax carb
Amongst all the weighty deliberations on improving safety,
maybe someone experienced and knowlegable about diaphrgam carburetors
could give me guidance.
I fly a PIK 20E , Rotax 501 unreliable engine which has been behaving erratically, surging but not misfiring that I can detect.
From the plugs I see rear cyl lean, front cyl a bit rich.
Does a split carb diaphragm enrich or lean the mixture?
thanks
John F
Old May 25th 20, 04:46 AM posted to rec.aviation.soaring
2G
Default rotax carb
thanks
John F
I am surprised that it runs at all - the diaphragm is critical for regulating fuel flow thru the carb:
https://www.youtube.com/watch?v=jWBre4-tHsg
You need to overhaul the carb which includes replacing the diaphragm.
Tom
Old May 25th 20, 04:44 PM posted to rec.aviation.soaring
Charles Longley
Default rotax carb
Before you get too excited about pulling that carb apart check the rubber mount between it and the engine. I’ve heard of them cracking out.
Old May 25th 20, 06:20 PM posted to rec.aviation.soaring
john firth
Default rotax carb
thanks
John F
An air leak was found at the shutoff valve , and fixed.
The carbs were pulled and the diaphragms examined; one is a bit stretched
but no holes found. Search for Tillotoson HC spares unsuccessfull.
Rebuilt everything with diaphragms swapped.
Engine now runs smoothly slightly lacking full power.
Rear cyl still hot as shown by EGT.
JMF
Old May 25th 20, 09:39 PM
Brett Brett is offline
Member
First recorded activity by AviationBanter: May 2006
JMF[/quote]
Hi John
I had a Pik30E in an earlier life and the rear cylinder always ran hotter due I expect to reduced cooling airflow as it is partially shielded by the front cylinder.
Regards
Brett
Have you ever experienced carb ice with an injector carb? flybynightkarmarepair Home Built 1 January 31st 05 01:48 AM
WANTED ROTAX 912 CARB SYNCHRONIZATION KIT kksksk Products 0 November 15th 04 09:45 PM
WANTED ROTAX 912 CARB SYNCHRONIZATION KIT kksksk Home Built 0 November 15th 04 09:43 PM
Carb temp guage vs. Iceman carb ice detector Mike Rapoport Piloting 1 September 28th 04 03:13 AM
carb ice john smith Owning 5 September 6th 04 12:41 PM
