High Wing Planes are Better Than Low Wing Planes
Old May 27th 18, 03:38 AM posted to rec.aviation.piloting
Clare Snyder
Default High Wing Planes are Better Than Low Wing Planes
On Sun, 27 May 2018 14:01:17 +1200, george152 wrote:
On 5/26/2018 12:00 PM, wrote:
Comparing airplanes to birds is moot in this respect. You have birds achieving thrust by reshaping the wing by utilizing muscular structures in the body and planes achieving thrust without manipulating the wing.
If we assume that low wing is a better design, then birds would still be high wing because muscles achieve work by pulling, so flying would be impossible!
High wing is best because you can get through gates at airstrips
This email has been checked for viruses by Avast antivirus software.
https://www.avast.com/antivirus
High wing planes are better if you want to look down
Low wing planes are better if you want to look up.
High wing planes are better if you need to land in scrub. - or land
on skis or floats.
Low wing planes are easier to fill wing tanks.
Old June 13th 18, 03:30 PM posted to rec.aviation.piloting
My initial point is that high-wing designs are inherently more stable
when moving through a dynamic atmosphere, and evolution proves it. We see
this in insects and bats as well. It's as simple as *not being top heavy*.
It's a gravitational factor.
Old June 19th 18, 10:06 PM posted to rec.aviation.piloting
Babbling nonsense.
Jim Pennino
Says you, the anal retentive dope who debates everything and
anything with non sequitur deflections and then finally after
trolling with a litany of insults, broken chains of thought
sequences, and non-deductive deductions, eventually just results
to lying, repeating misinformation ad nauseam, and packaging
the entire mess laden with grammatical errors that a fifth
grader wouldn't make.
Stay out of airplanes asshole.
Old June 19th 18, 11:25 PM posted to rec.aviation.piloting
Babbling nonsense.
Jim Pennino
**** off and die idiot.
Jim Pennino
Old October 29th 18, 03:05 AM posted to rec.aviation.piloting
John Huthmaker
Well thank goodness commercial airlines dont use low wing planes. I wouldnt want to travel in an inherently unstable death trap. Did I mention I fly Pipers because I like them much better than Cessnas?
Classic High wing Low wing collision user Soaring 1 May 17th 08 12:27 AM
Low wing landing, high wing taking off...oops [email protected] Piloting 1 May 16th 08 09:41 PM
Soft field landings - low wing vs high wing aircraft Justin Gombos Piloting 19 May 23rd 07 05:21 AM
High wing to low wing converts...or, visa versa? Jack Allison Owning 99 January 27th 05 11:10 AM
End of High wing low wing search for me dan Home Built 7 January 11th 04 10:57 AM
