LXNav S80 Vario Digital Input Wiring Question
Old July 14th 16, 08:35 PM posted to rec.aviation.soaring
Gianni Isotope
Default LXNav S80 Vario Digital Input Wiring Question
I would like to wire the sensor switches that I already have in place for my landing gear and spoilers to my LXNav S80 vario. The S80 user's manual offers little information on how to accomplish this. Hopefully, others before me have got this working, and can offer some advice.
I understand that the IN0 and IN1 pins of the D15 connector are to be used. Are these pins TTL-level digital inputs with internal pull-up resistors, such that they should either be left open (i.e., floating) or grounded, depending upon the position of the sensor switch?
Or, are there no internal pull-up resistors, such that I am required to supply a positive DC voltage or ground, depending upon the position of the sensor switches? If so, what voltage is expected?
Also, are these digital inputs isolated in any way (i.e., optically-isolated), or do I need to use shielded cabling to avoid injecting noise into my radio?
Thanks in advance,
Jordan
Old July 14th 16, 11:16 PM posted to rec.aviation.soaring
Greg Delp
Thanks in advance,
Jordan
The input 0 and 1 pins put out a low voltage that will run through your switch and then via your switch ground wire back to a common ground with the S80 unit itself. You are able to select via the hardware menu whether you the switch(s) need to be open or closed for the selected statement on the menu to be true.
New LXNAV S8 vario Paul Remde Soaring 5 October 12th 15 04:14 PM
Wanted: LXNav V7 Vario Greg Delp Soaring 0 April 1st 14 10:18 PM
New vario by LXNAV [email protected] Soaring 6 May 22nd 13 11:15 PM
LXNav V7 vs Butterfly vario? Chris Davison[_2_] Soaring 32 January 8th 13 09:37 AM
XC Soar with Vario input Brad[_2_] Soaring 3 September 9th 09 08:14 PM
