Q about mic wiring
Old May 30th 05, 04:55 AM
ken ward
Default Q about mic wiring
I see that for my Peiker dynamic mic, the red wire typically connects to
the MIC pin of the radio, and the yellow wire (with or without the
braided shield) typically connects to the MIC GND of the radio.
In a typical installation, do people actually run a coax type wire with
a shielded braid (or maybe a foil shield) from the radio connector out
to the mic (where the center conductor would be MIC and the braided
shield MIC GND), or do people just run two insulated wires side-by-side?
Although there's quite a bit of mic/radio info available in the
searchable Google archive of r.a.s, I didn't see anything on this topic.
Ken
Old May 30th 05, 10:18 AM
Tim Newport-Peace
X-no-archive: yes
In article
..com, ken ward writes
Ken
I am not familiar with that particular microphone but from what you say
it would seem to be intended to be a Balanced Microphone. Balanced
Microphones are not used on any Glider Radio that I know of, but are
used as Unbalanced microphones by connecting one leg to ground.
A dynamic Microphone produces a low signal level, very much lower than
an electret type. The microphone cable should _always_ be screened. If
you don't, you can induce noise into the system and this is most
probable in an un-balanced dynamic microphone system.
It is not unknown for RF leaking from the transmitter to be collected by
the microphone cable and re-transmitted as feedback, even with screened
cable (of which there are a variety of qualities). I would always try to
keep the microphone cable as far as possible from the antenna cable.
Tim Newport-Peace
"Indecision is the Key to Flexibility."
Old May 31st 05, 10:33 PM
Tim Mara
use "either colored wire" as Mic INPUT, use the shield and theOTHER colored
wire and use both as MIC GROUND
tim
Wings & Wheels
www.wingsandwheels.com
"ken ward" wrote in message
Ken
Dittel FSG40S wiring connections Anthony Manwaring Soaring 3 June 23rd 14 05:42 PM
LX1000 Wiring Diagram Luke Roberts Soaring 2 April 18th 05 09:26 AM
ball 101A wiring diagram coneil Soaring 4 June 22nd 04 06:55 AM
Piper Cheyenne Wiring Diagrams Steve Restoration 0 April 7th 04 03:03 AM
Dittel FSG50 wiring diagram Chris Davison Soaring 0 October 15th 03 07:23 AM
