Discus b lead ballast plates wanted
On Wednesday, March 3, 2021 at 3:22:01 PM UTC-5, wrote:
Thank you, that is much appreciated. Another option that avoids flames and hot lead gases is to buy sheet lead from McMaster Carr supply. It would involve cutting a bunch of discs out of sheet and drilling holes which is easy in thin sheet. Anything up to 1/8 thick is easily cut with tin snips. If you know size and stack height it is easy to match the factory weights. Good luck UH |
Similar Threads | ||||
wanted: ballast box for 1-26 | Moshe Braner | Soaring | 0 | December 9th 20 10:13 PM |
Discus tail ballast leak | Dee[_2_] | Soaring | 9 | August 26th 20 05:32 AM |
Schweizer Ballast Box Wanted | [email protected] | Soaring | 1 | May 11th 09 04:07 AM |
Ballast dump time Discus | J. Nieuwenhuize | Soaring | 7 | April 27th 07 05:56 AM |
lead tail ballast | [email protected] | Soaring | 15 | November 12th 06 11:18 PM |
