Transponder Landing System ???
Old September 17th 04, 04:17 AM
C Kingsbury
Roy Smith wrote in message ...
In article ne.com,
Andrew Gideon wrote:
C Kingsbury wrote:
Out East I can't think of any Class D
fields that don't have at least 1 ILS, but perhaps in other regions
that's sometimes the case?
Sniff Now you've made me feel badly about my home class D airport in
Northern New Jersey, CDW, that has no precision approach (but we do have a
localizer).
I'd feel really badly did I not know that Hartford, in CT, also lacks a
precision approach. They don't even have a localizer; just an LDA.
[I think that this LDA lets you off pointing not at the airport, but at a
now closed airport across a river. But I may be recalling incorrectly.]
- Andrew
In addition to Hartford and Caldwell, there's also Danburry which only
has a localizer.
Duh, Beverly (BVY) which I've flown into also has a localizer-only approach.
Post first, think later...
Best,
-cwk.
Old September 19th 04, 04:03 AM
Richard Kaplan
"C Kingsbury" wrote in message
om...
With WAAS underway, it seems predictable that non-precision approaches
will be joining colored airways in the dustbin of history. If the FAA
This is unlikely when one considers that a number of airports which
currently have WAAS approaches have non-precision minimums which are lower
than the WAAS minimums.
Also consider that WAAS approaches can only be designed to airports clear of
obstructions according to TERPS; thus lots of airports will remain eligible
only for non-precision approaches.
Richard Kaplan
www.flyimc.com
Old September 19th 04, 04:45 AM
Barry
which are lower than the WAAS minimums.
Do you have some examples?
  #24
Old September 19th 04, 07:59 PM
C Kingsbury
"Richard Kaplan" wrote in message news:1095562995.6eAYDxNjAfSfAEnPws5pJw@teranews. ..
om...
Hmmm, is this just a matter of the TERPS guys being conservative until
WAAS is better understood? I can't see any case where WAAS provides
poorer positional accuracy than a VOR, and it should at least be very
close to the performance of a localizer.
Heh. Good point, I hadn't thought about that so much.
Actually, an interesting case-study can be seen looking at the
different approaches for Rutland, VT
(http://www.airnav.com/airport/KRUT) which is down in a valley with a
gaggle of towers. With its proximity to several major ski resorts it
gets a fair deal of light bizjet traffic.
Approach | Minima AGL (all straight-in)
LOC 19 | 2100
VOR-DME 19 | 1800
GPS 19 | 1400
LOC+DME 19 | 900
According to these plates, the angle of descent in the final segment
ranges between 3.35-3.72 degrees, as compared to a 3deg standard ILS.
Is there any reason why using WAAS, it wouldn't help to basically
setup a virtual glideslope that brings the plane down to the minimum
at the appropriate point, and then "levels off" until the missed
approach point? Well, other than the fact that perhaps no one has
thought about designing such a procedure, I suppose...
Still, at the very least every airport should be able to support
minimums equivalent to those that would be provided by a LOC-DME
installation. You can't change the dictates of terrain but at least
you don't have to pay to install and maintain a shed full of radio
equipment.
Best,
-cwk.
"bush flying" in the suburbs? [email protected] Home Built 85 December 28th 04 11:04 PM
Diamond DA-40 with G-1000 pirep C J Campbell Instrument Flight Rules 117 July 22nd 04 05:40 PM
Fixing the Transponder with Duct Tape and Aluminum Foil Ron Wanttaja Home Built 45 March 14th 04 12:18 AM
Off topic - Landing of a B-17 Ghost Home Built 2 October 28th 03 04:35 PM
2nd update on Review of Plasma II Ignition System MikeremlaP Home Built 8 July 22nd 03 01:37 AM
