Testing for Attachments
Old February 24th 21, 07:11 PM posted to rec.aviation.soaring
Dan Marotta
Default Testing for Attachments
Well, It worked for me!
Dan
5J
On 2/24/21 12:00 PM, Dan Marotta wrote:
Since I use the Thunderbird email client to read RAS and I just
discovered that I can attach a file to a message, I thought I'd do a
test run.Â* Anybody out there see the picture?
Old February 24th 21, 07:56 PM posted to rec.aviation.soaring
Guy Acheson[_2_]
No photos or attachments.
Old February 24th 21, 08:02 PM posted to rec.aviation.soaring
Eric Greenwell[_4_]
Dan Marotta wrote on 2/24/2021 11:11 AM:
Dan
5J
Since I use the Thunderbird email client to read RAS and I just discovered that I can attach
a file to a message, I thought I'd do a test run.* Anybody out there see the picture?
All I got was this message, which did not have an attachment.
Old February 24th 21, 08:37 PM posted to rec.aviation.soaring
Eric Greenwell[_2_]
Dan
5J
test run. Anybody out there see the picture?
I did not see the original message using my email client (Seamonkey - nearly identical to Thunderbird), nor did I see it using Google Groups. Seems like it might be Thunderbird quirk, because RAS is a Usenet group that does not support images.
How do you connect to RAS? I use the nntp.aioe.org server.
Old February 24th 21, 08:49 PM posted to rec.aviation.soaring
Darryl Ramm
It worked for anybody using a modern USENET reader. The old USENET, which is where rec.aviation.soaring really lives is all ASCII characters and supported attachments by converting things like Images to a ASCII text encoding. Thunderbird (a great USENET reader) is making this simple for you, but under the covers it's converting that jpg image to the text encoding and converting it back when you read the message. Folks with ancient USENET readers might see the encoded text as
--------------0DAD4A81AAF329A2D963103A
Content-Type: image/jpeg;
name="T-Birds.jpg"
Content-Transfer-Encoding: base64
Content-Disposition: attachment;
filename="T-Birds.jpg"
/9j/4AAQSkZJRgABAgEBLAEsAAD/7Q3yUGhvdG9zaG9wIDMuMAA4QklNA+0AAAAAABABLAAA
AAEAAQEsAAAAAQABOEJJTQQNAAAAAAAEAAAAeDhCSU0D8wAAAA AACAAAAAAAAAAAOEJJTQQK
AAAAAAABAAA4QklNJxAAAAAAAAoAAQAAAAAAAAACOEJJTQP1AA AAAABIAC9mZgABAGxmZgAG
And Google Groups... which is a pretty crappy front-end to USENET... well it just ignores all attachments.
Darryl
Dan
5J
Old February 24th 21, 09:08 PM posted to rec.aviation.soaring
Martin Gregorie[_6_]
--------------0DAD4A81AAF329A2D963103A Content-Type: image/jpeg;
name="T-Birds.jpg"
Content-Transfer-Encoding: base64 Content-Disposition: attachment;
Darryl
Dan 5J
Not here with the Pan newsreader - it wouldn't display them but did save
them - without saying where.
Martin | martin at
Gregorie | gregorie dot org
Old February 24th 21, 09:22 PM posted to rec.aviation.soaring
Later....
Found 'em (after reading Pan Help) :-(
Both JPG image and message readable.
A useful discovery: I hadn't realised that using attachments was possible.
Martin | martin at
Old February 24th 21, 11:48 PM posted to rec.aviation.soaring
Dan Marotta
All us glider guys that want the modern technology in our cockpits are
inexplicably still using smoke signals to communicate on RAS. Go figure.
Dan
5J
Later....
Old February 25th 21, 04:20 AM posted to rec.aviation.soaring
Eric Greenwell[_4_]
Darryl Ramm wrote on 2/24/2021 12:49 PM:
name="T-Birds.jpg"
Darryl
Dan
5J
I attached an image to this posting. Let's see if anyone sees it!
OK, it wouldn't send because of "invalid content type", probably the nntp.aioe.org server
choking on it. I probably need to use a different server to make it work, like Dan's
eternal-september.org.
Never seen this done...Wildcat fighters testing their machine guns aboard Ranger off North Africa, November 1942. - wildcats testing guns 1942.jpg Miloch Aviation Photos 2 January 20th 19 05:07 AM
Northrop F-89 Scorpion 20mm gun testing - 19 attachments (1/2) john Szalay Aviation Photos 0 July 11th 16 04:40 PM
C-119 MODEL - 3 attachments (1/2) [email protected] Aviation Photos 4 December 6th 07 02:48 AM
