Go Back   Home » AviationBanter forum » rec.aviation newsgroups » Aviation Marketplace
Professional Grade Universal IC Chip Programmer, May Be Usefull For Modern Aviaonics Devices?
Old July 11th 05, 07:18 AM
NW_PILOT
Default Professional Grade Universal IC Chip Programmer, May Be Usefull For Modern Aviaonics Devices?
Professional Grade Universal IC Chip Programmer, Supports 9,600+ Diffrent
IC Chips. This Is a Professional Grade I C Chip Programmer "Not Some Home
Brew Kit"
List Of IC Chips It Will program "Device List" http://www.warflying.net/spv
Comes compleate with all Cables & Software needed to program IC Chip's
$375.00 Free Shipping.
Call 1-503-475-3347
Specs.
48 Pin ZIF socket with universal pin-drivers. Expandable to 100 pins
More than 9,600+ devices are currently supported
Interface with LAPTOP, PC, PS/2 or compatibles through printer port
Accepts standard file formats: JEDEC, INTEL (Extended) HEX, Motorola S
record
Manages 16 and 32-bit word split (Set Programming)
Support most compiler in JEDEC format including ABEL, CUPL, PALASM, TANGO
PLD, OrCAD PLD, PLD Designer and ISDATA
Features Test Vector capability and multiarray fuse map editor
Test TTL/CMOS logic ICs and Dynamic/Static Random Access Memory devices
Menu/window driven software interface which includes Macro and Batch
Functions
Optimum programming for each individual device
Automaticly Identifies the manufacturer and type of E(E)PROMs, Auto
identifies
TTL/CMOS logic IC
High programming speed.
Device insertion and poor-pin-contact check
Support Windows 95/98
Support 1.8v Low voltage devices
Dual range ( 90V ~ 240V ) switching power supply adapter
PIREP: AirMap 1000 (Long) Mike 'Flyin'8' Piloting 50 March 22nd 05 03:34 PM
Universal IC Chip Programmer $600.00 OBO NW_PILOT Piloting 1 November 5th 04 02:14 PM
