On Electric Aircraft
Old February 11th 20, 06:09 PM posted to rec.aviation.soaring
Bob Kuykendall
Default On Electric Aircraft
On Tuesday, February 11, 2020 at 5:15:04 AM UTC-8, Tim Newport-Peace wrote:
Not Quite True.
Since a charged battery contains a greater total amount of energy than a
dead battery, the earth's gravity will pull more strongly on it.
But you will have trouble measuring the difference ;¬))
But seriously, no. Energy in and of itself has no mass. A an old-time watch or windup toy has the same mass regardless of whether it is wound or unwound.
Old February 11th 20, 06:16 PM posted to rec.aviation.soaring
Bob Kuykendall
On Tuesday, February 11, 2020 at 4:33:26 AM UTC-8, Martin Gregorie wrote:
..The one thing we both missed, though is that a good brushless motor plus
its controller will be a lighter and smaller than the equivalent ICE
piston engine driving a propeller...
Not only that, but it delivers smoother power with less vibration, delivers it the moment it is started, requires less service infrastructure (starting, lubrication, cooling, exhaust, etc), and can easily be positioned for stowage. It runs cleaner and cooler and more predictably under a wider range of conditions, and is more easily monitored for performance and troubleshooting.
--Bob K.
Old February 11th 20, 06:23 PM posted to rec.aviation.soaring
Martin Gregorie[_6_]
Not Quite True.
a dead battery, the earth's gravity will pull more strongly on it.
or unwound.
....but an electron does have mass, just not very much:
9.1093837015 × 10^-31 kg
Not that it matters, because as many electrons flow into a discharging
battery as flow out.
Martin | martin at
Gregorie | gregorie dot org
Old February 11th 20, 06:34 PM posted to rec.aviation.soaring
plus its controller will be a lighter and smaller than the equivalent
ICE piston engine driving a propeller...
Another thing, but this probably doesn't affect us much: a brushless
motor, which all these units are, has its rpm set primarily by the rate
at which the controller switches power round its (static) field coils
and, when driving a propeller, isn't much affected by the load its
working against. Its one reason electric brushless motors are popular
with the RC and CL aerobatic crowd - the nearly constant RPM causes
airspeed on uplines and downlines to be more constant than it ever was
with IC engines.
Martin | martin at
Old February 11th 20, 06:56 PM posted to rec.aviation.soaring
Dan Marotta
And who outside of the media did not understand that?
On 2/10/2020 3:28 PM, Eric Greenwell wrote:
kinsell wrote on 2/10/2020 7:59 AM:
On 2/10/20 8:43 AM, Dan Marotta wrote:
A couple of very good perspectives HERE
https://www.avweb.com/features/reader-mail/top-letters-and-comments-february-7-2020/?MailingID=280&utm_source=ActiveCampaign&utm_mediu m=email&utm_content=Bryant+Crash+Prelim%2C+Drone+C ertification+NPRM&utm_campaign=Bryant+Crash+Prelim %2C+Drone+Certification+NPRM-Monday+February+10%2C+2020.
Let the flames begin...
Dan, 5J
Yep.Â* Came across an article from COPA (Canadian Owners and Pilot's
Association) filling in some the the details of the Harbour Air
plane. It was so stuffed full of batteries there was hardly any
useful load left.Â* Which puts it more in the category of publicity
stunt than a serious attempt to develop an electric plane.Â* And of
course calling it the first all-electric commercial aircraft is
disingenuous in the extreme.
https://copanational.org/en/2019/12/...zQBJD3aCPb93FA
The article made clear it's _test_ plane, not prototype for the
commercial version. That version will use a different chemistry Li
battery that is significantly lighter.
"The flight was not in a commercial aircraft in the sense that it was
certified to carry passengers – it is a prototype used in the
certification process. As such, the flight was made for ‘proof of
concept’ purposes only."
Dan, 5J
Old February 11th 20, 07:32 PM posted to rec.aviation.soaring
Dan Marotta
What a wonderful way to spend a snowy morning, discussing the weight of
a full versus an empty battery!
What if we talked in terms of mass instead of weight? :-D
Seriously, I got a lot of entertainment after the thread went off topic
as is so normal with RASicrucians.Â* I especially liked the comparison
that Bob made of a wound versus unwound watch or toy. I've been banging
my head against the wall trying to see that in the context of the Laws
of Conservation of Matter and Energy.
More coffee is in order...
with IC engines.
Dan, 5J
Old February 12th 20, 05:19 AM posted to rec.aviation.soaring
Tango Whisky
You mean that a glider hs a higher mass after releasing from tow because you added potential energy??
Old February 12th 20, 06:14 AM posted to rec.aviation.soaring
kinsell
Ummm, the COPA article is not the message that Harbour Air and Magnix
have been putting out.
This is representative of the story they tell, indicating the prototype
is ready for certification:
https://www.flightglobal.com/airline...135711.article
And yes, there's lots of people not associated with aviation that are
being mislead by this.
-Dave
Dan, 5J
Interesting Electric Aircraft Video Nick Kennedy[_3_] Soaring 0 December 15th 18 02:43 PM
VTOL Electric Aircraft 2G Soaring 5 February 10th 18 07:47 PM
SunAero Electric Aircraft Larry Dighera Piloting 0 September 27th 14 04:52 PM
Solar Electric Powered Aircraft Larry Dighera Piloting 33 November 6th 05 08:37 PM
Solar Electric Powered Aircraft Larry Dighera Soaring 31 November 6th 05 08:37 PM
