Cessna 150 Price Outlook
Old October 1st 03, 04:59 PM
Ron Natalie
"John Galban" wrote in message om...
I've flown and spun 150/160s that were approved for spins in the
Utility Category.
Let me be more exact. The PA-28-150 and PA-28-160 are NOT
certficated in the utility category, hence no spins. The PA-28-151
and PA-28-161 are certificated in the utility category.
The PA-28-140, -180, -181 are certificated in the utility category
For those models that are certificated with for utility category operations.
1. You have to get the CG in the utility envelope.
2. You have to not have the 2150 gross weight increase.on the -140.
3. There is a serial number limit on the -180 for utility category operations.
4. You can only use the two front seats.
  #52
Old October 1st 03, 05:35 PM
Ron Natalie
"Ron Natalie" wrote in message m...
Utility Category.
Oh, and by the way, I forgot one important thing. If your PA-28 can be
operated in the utility category, it will be placarded as such (with the gross
weight for that category). That's perhaps the easiest way to tell (provided
your aircraft is airworthy).
  #53
Old October 1st 03, 10:59 PM
Ron Natalie wrote:
: I've flown and spun 150/160s that were approved for spins in the
: Utility Category.
: Let me be more exact. The PA-28-150 and PA-28-160 are NOT
: certficated in the utility category, hence no spins. The PA-28-151
: and PA-28-161 are certificated in the utility category.
Hrmm... sounds illegal to me then?
: The PA-28-140, -180, -181 are certificated in the utility category
: For those models that are certificated with for utility category operations.
: 1. You have to get the CG in the utility envelope.
Of course.
: 2. You have to not have the 2150 gross weight increase.on the -140.
Probably not too many of them left.
: 3. There is a serial number limit on the -180 for utility category operations.
Probably the old (non-clamshell cowling) version?
: 4. You can only use the two front seats.
Of course
Mine need not legally apply since the engine upgrade expressly
says Normal only.
Thanks for the info though... I would think it's pretty much a legal
issue. The important thing would be to keep it loaded in the Utility CG
range. Other than that there's no real difference between the airframes.
-Cory
* The prime directive of Linux: *
* - learn what you don't know, *
* - teach what you do. *
* (Just my 20 USm$) *
  #54
Old October 2nd 03, 12:42 AM
Neal
You sure about that? The Checkerbird's paperwork says it has a max
gross weight of 2150 when operated in the normal category, 1950 in the
utility category. It has both the original placard on the panel, plus
the AFM text stating that spins are an approved aerobatic manuever
when operated in the utility category with no aft baggage pax.
I'm far too chicken to try spinning it however. ;-)
  #58
Old October 2nd 03, 04:17 AM
JJS
"Neal" wrote in message
the -140.
plus
Same here! My 2150 pound g.w. 1966 Cherokee has the same placard on
the panel. It also has four seats. I pulled out the flight manual,
also.
The airplane flight manual maneuvers section lists entry speed for
spins, steep turns, lazy eights and chandelles.
The Placards section has this: "For spin recovery, use full rudder
against spin, followed immediately by forward wheel".
I also looked at my copy of the type certificate and saw nothing
prohibiting spins.
Joe Schneider
8437R
(Remove No Spam to Reply)
X-No-archive: yes
  #59
Old October 2nd 03, 03:26 PM
John Galban
"Ron Natalie" wrote in message om...
Very interesting! Now I'm going to have to go back and check my
logbook. I was pretty sure they were 150/160s that I'd spun (and now
I'm not). They had the placard with manuever entry speeds, including
spins, in the utility category.
Odd that the 150/160 would not be certified in the utility category
and the -180 is. They're basically the same airframe. Where did you
get the above info? TCDS?
  #60
Old October 2nd 03, 03:29 PM
Ron Natalie
Yep.
Floridians Are Hit With Price Gouging X98 Military Aviation 0 August 18th 04 04:07 PM
Cessna buyers in So. Cal. beware ! Bill Berle Home Built 73 June 25th 04 04:53 AM
1977 Cessna 182 Special Price Bill Davidson Aviation Marketplace 0 June 7th 04 11:25 PM
FORSALE: HARD TO FIND CESSNA PARTS! Enea Grande Aviation Marketplace 1 November 4th 03 12:57 AM
