Tiny vacuum pump
Old January 20th 04, 12:04 AM
Jim Weir
Now *that's* clever. I admire clever.
Mike Patterson
-Those aquarium air pumps pull air from around the case.
-How about placing one inside a cheapo tupperware-type container with a
-"suck" port mounted on the container, you'd also need to run a "blow"
-port from the pump's normal output through the container wall.
-HTH
-Mike Patterson
-Please remove the spamtrap to email me.
http://www.rst-engr.com
  #32
Old January 20th 04, 03:24 AM
Bob Chilcoat
Jim,
That air compressor sprayer I gave you a couple of years ago is just a
venturi. Use the liquid imput end to generate the vacuum. Unless ypu lost
it, you already have what you need.
Bob (Chief Pilot, White Knuckle Airways)
"John Mireley" wrote in message
Jim Weir wrote:
Does anybody have an idea on how to make a tiny little vacuum pump on
the order
of an aquarium pump or so that will draw just a few inches of water?
Preferably
110, but I can rig up a 12 volt supply if necessary.
If you have a compressor, use a venturi vacuum generator.
Harbor freight has them for about $10 from time to time.
  #33
Old January 21st 04, 03:44 AM
clare @ snyder.on .ca
On Mon, 19 Jan 2004 17:45:27 -0500, Mike Patterson
On Sat, 17 Jan 2004 19:03:40 GMT, Tom Pappano
Jim Weir wrote:
Does anybody have an idea on how to make a tiny little vacuum pump on the order
of an aquarium pump or so that will draw just a few inches of water? Preferably
Just get a little "mityVac" hand pump used for testing vac advance etc
on cars.
Or if you really need it mechanized, make an adapter for your vacuum
cleaner with an adjustable bleed
The reason I say this is that I'm getting ready to pack a fairly large number of
bags with used but serviceable engine parts (valves, pistons, etc.) and I'd like
to put each part in a "baggie" (sandwich bag or equivalent) along with a little
preservative oil, and then suck the baggie down with a football needle stuck
into the top closing mechanism just before sealing.
Thoughts?
HTH
Mike Patterson
Wet vs Dry Vacuum Pump Fastglasair Home Built 1 December 15th 04 05:17 PM
Windmilling Prop & Vacuum Pump Matt Young Instrument Flight Rules 14 October 14th 04 08:08 PM
Remove oil seal from vacuum pump adapter on Lycoming IO320 HOW????? Ron Home Built 2 February 24th 04 04:34 PM
Tiny vacuum pump Jim Weir Home Built 41 January 24th 04 05:42 AM
Battery and Vacuum pump PaulaJay1 Owning 3 January 16th 04 04:22 PM
