"A" vs "B"
Old September 30th 15, 08:45 PM posted to rec.aviation.soaring
C2
Default "A" vs "B"
How much performance advantage does an "A" model (Ventus or Discus) have over a "B" model. Looking for some numbers, but I can't seem to find anything definitive.
Old September 30th 15, 09:38 PM posted to rec.aviation.soaring
Bob Gibbons[_2_]
Default "A" vs "B"
On Wed, 30 Sep 2015 12:45:17 -0700 (PDT), C2
Dick Johnson tested and reported the results on his Ventus A in
December 1981 SOARING, and followed this up in June 1982 with his
report on a Ventus B.
Page 30 of the 2nd article shows an overlay of the A vs B polar plots.
Only over 100 kts can you see a small seperation develop between the
two plots.
Perhaps a more important factor is the small cockpit of the A model,
and the lack of the self-connecting controls of the B model.
Check the SSA website for the full reports.
Bob
Old September 30th 15, 10:09 PM posted to rec.aviation.soaring
Richard[_9_]
Default "A" vs "B"
two plots.
Bob
My Ventus b has self-connecting controls.
Richard
Old October 1st 15, 02:35 AM posted to rec.aviation.soaring
Default "A" vs "B"
Only the Ventus has the different control connections between A&B, IIRC. The Ventus A is only auto-connect elevator. Ventus B and all Discii are full auto-connect.
FWIW, the FAI handicaps the two the same. The SSA appears to give a lower handicap (lower == higher performance in SSA-land) to the B, but that is likely due to the higher empty weight of the B vs the A.
Old October 1st 15, 03:26 AM posted to rec.aviation.soaring
Tim Taylor
Default "A" vs "B"
General rule of thumb is about 0.5 percent. The true advantage comes in wider wing loading range from the lower empty weight. Great gliders if you fit but more difficult to sell to the "average" American pilot.
"VideO Madness" ( Soldiers...) "GoD Hates FAGS!!! (He sO righteOusly DoES)" Colonel Jake Naval Aviation 0 March 1st 10 12:14 AM
Phrase "landing runway" vs. "cleared to land" Robert M. Gary Instrument Flight Rules 137 February 5th 08 05:32 PM
Old polish aircraft TS-8 "Bies" ("Bogy") - for sale >pk Aviation Marketplace 0 October 16th 06 07:48 AM
