Mini-Winch for FES
Old June 5th 20, 05:07 AM posted to rec.aviation.soaring
son_of_flubber
Default Mini-Winch for FES
On Thursday, June 4, 2020 at 6:38:23 PM UTC-4, Kenz Dale wrote:
3) No chance of ripping the wings off the plane due to an over-exuberant winch operation
That possibility is reliably eliminated by a calibrated weak link in the winch launch rope.
  #52
Old June 5th 20, 12:04 PM posted to rec.aviation.soaring
Martin Gregorie[_6_]
winch launch rope.
Good modern winches monitor and adjust cable tension rather than blindly
using throttle position. Skylaunch units have a basic (analog?) computer
which accepts the glider type and surface wind speed before each launch.
I've yet to have a bad launch off one.
Martin | martin at
Gregorie | gregorie dot org
  #53
Old June 5th 20, 03:31 PM posted to rec.aviation.soaring
WB
On Thursday, June 4, 2020 at 5:38:23 PM UTC-5, Kenz Dale wrote:
On Thursday, March 5, 2020 at 1:22:48 AM UTC-5, son_of_flubber wrote:
I'd rather take my chances on something that would accelerate the glider 0-50 knots in 50 meters with the FES running from the very start of the roll. This would increase available runway ahead for launch failure and conserve a bit of battery power. Fully automated with pilot pushing the go button.
This is really the idea right here. As we increasingly embrace self-launch eGliders, I think we'll see more and more gliders operating out of small airports without the benefit of a club. Thus, what's missing in the conversation is a consideration of the CONOPS (CONcept of OPerationS) for single-person launching.
Cool idea, however, it has sort of been tried before. One of our club members posted this link to a film documenting initial tests with a semi-autonomous auto-launch system. Seemed to work, but with significant wear on the launch vehicle.
https://youtu.be/wwsa4PVYMJY
  #54
Old June 5th 20, 03:59 PM posted to rec.aviation.soaring
Excellent.
For an FES ground assist, you need enough energy for a rope break like return to the field when the FES does not work.
I there a safe and economical way to make a winch that can just get you to 300 feet?
Might be some minor issues with the design example in the video.
  #55
Old June 5th 20, 05:58 PM posted to rec.aviation.soaring
Excellent.
Good and cheap are mutually exclusive. A good, safe machine won't be cheap.
  #56
Old June 5th 20, 06:26 PM posted to rec.aviation.soaring
Right, but I thought the idea of the original question was to see if sacrificing some good (higher than 300 foot tow?) might make cheap and safe possible.
Seems like a small corner case until there are lots more FES, but still fun to think about.
  #57
Old June 5th 20, 06:50 PM posted to rec.aviation.soaring
WB
A light duty winch to get you to 300 feet would still require all the same components as a heavy duty winch designed to get a Duo to 2000'. Assuming you will climb at a relatively shallow angle, you could get away with somewhat less power than a typical glider winch because you won't need to climb steeply as is done in a regular winch launch. Also, because line tension will be less in the shallow climb, your winch drum can be lighter. Brakes are critical on a winch to manage inertia of the drum/line and to put some tension on the in when reeling it out. A lighter system could have correspondingly lighter brakes. Your winch line will be under less tension, and with a low launch rate, wear would not be a big issue. You could forego expensive Dyneema line and just use polypropylene (might be a false economy eventually). These would all be small increments of "lighter, smaller, cheaper". Probably not enough to justify building it. My guess is it would be better to buy/build a regular winch or go with auto launch. Hard to get cheaper and simpler than an old car, a bucket of rope, and a tow release on a trailer hitch.
  #58
Old June 5th 20, 07:00 PM posted to rec.aviation.soaring
Agreed! It's a fun thought experiment for a growing sector of the sport.
For me, the issue is that if I have a setup which can get me to 300', it can get me a lot higher for minimal extra effort. 300' would mean about 600' of linear space, which is unlikely to fit in the area before a runway. So once I'm using any part of the runway, I might was well use the entire length.
From a mechanical perspective, the only substantial difference between 300' and 3000' is the length of rope and the total energy required. The angles, forces, and power stays the same.
Some crucial distinctions of a 100' long catapult-style launch are that there's no hardware on the runway so it can plausibly be completely autonomous; the angles are purely horizontal so the spooling system is simplified and the hook cannot drift down onto the runway; a 3 second launch means that motor cooling is not an issue due to the thermal mass of the motor; and a launch failure is very graceful, with a worst case result of rolling down the runway at a leisurely 30-40kts.
  #59
Old June 5th 20, 07:10 PM posted to rec.aviation.soaring
Nick Kennedy[_3_]
WB
Thats a good Vid!
Do you know what movie that was taken from?
Nick
T
  #60
Old June 5th 20, 07:34 PM posted to rec.aviation.soaring
AS
I would advise against using polypropylene line since it has a much higher elongation compared to UHMWPE lines. It would most likely lead to a very unsteady launch with a lot of surging - like hanging on a bungee cord. Spectra or Dyneema have an elongation very close to what a steel cable has but at about 1/10 of the weight. That also plays into the overall equation for accelerating the line and then stopping everything with your drum brakes.
Rather than building something on the 'Hold my beer - watch this' principle, spend the money and get the right stuff.
Uli
'AS'
LX Mini Map Andrew Blanchard Soaring 36 March 8th 14 04:07 AM
Mini-Imp Curt Fennell Home Built 7 November 10th 09 12:43 PM
Best winch metrics - what is the best winch operationally? Bruce Soaring 19 July 19th 09 11:45 AM
LIppmann reports a 950 meter winch launch with their Dynatec winch line - anything higher? Bill Daniels Soaring 20 December 27th 04 12:33 AM
Mini Imp Randall Robertson Simulators 3 December 17th 03 05:56 AM
