#11
"Robert Bonomi" wrote in message ... *sigh* this is REALLY a 'no-brainer'. Get *two* timers. That *is* great! I never thought of the removable tripper, so no on selected. Only problem is that the 7 day timers are pricey, aren't they? Again, good thinking. I had the two timers, you got the rest of it right. -- Jim in NC |
"Morgans" wrote in message ... "Robert Bonomi" wrote in message ... *sigh* this is REALLY a 'no-brainer'. Get *two* timers. That *is* great! I never thought of the removable tripper, so no on selected. Only problem is that the 7 day timers are pricey, aren't they? Again, good thinking. I had the two timers, you got the rest of it right. -- Jim in NC The 7 day timers can be found for under $20... Got one the other day. Now I just need the one day that runs as described. KB |
Kyle,
How about one of these? http://www.foxelectricsupply.com/con...ProductNo=SS7C http://www.foxelectricsupply.com/con...sProductNo=SS8 Jeff "Kyle Boatright" wrote in message ... I'm looking for a timer with a specific functionality. I want to be able to set the thing to turn on an electrical appliance at a set time, then turn it off after a selectible time. I don't want the thing to come on again until I tell it to. Not one day later or 7 days later.The application is for the pre-heaters on my RV-6. I've got a battery warmer and a sump heater. The low-down is that I work 15 minutes from the airport, so I can drop by very easily at lunch or right after work to set a timer if I think I'm going to be flying the next day (this is particularly useful for flights early on Saturday morning). There are many timers that will support this function. The problem is that most of 'em will then turn on again at the same time the next day, and the next, and the next. Or maybe, they will turn on a week later. The situation I want to avoid is where I set the timer for, say, Saturday morning, then plans go bad and I don't get to the airport for a week or two and the heaters run on a daily basis or weekly basis until I reset or unplug the timer. I've tried the big box stores, Grainger, etc. and have not found a timer that works the way I want. Suggestions? KB |
Morgans wrote: "Robert Bonomi" wrote in message ... *sigh* this is REALLY a 'no-brainer'. Get *two* timers. That *is* great! I never thought of the removable tripper, so no on selected. Only problem is that the 7 day timers are pricey, aren't they? Depends what you consider 'pricey', I guess. ,grin I was at the Blue BORG (Lowes), today. They had 7-day timers for under $15, and removable tripper one-day ones, for under $10. Note: The *only* reason for the 7-day timer is to allow one to set thing up "more than one day" in advance. If you'll never need more than 24 hours 'lead time', you can use a "daily" timer for timer #1, as well. Again, good thinking. I had the two timers, you got the rest of it right. I've used that 'off only' tripper set-up for various things for more than 30 years. It is absolutely *wonderful* where you have things that might get 'left on' (usually because somebody just "forgot" to turn 'em off), and not discovered for an extended period. |
Kyle Boatright wrote: "Morgans" wrote in message ... "Robert Bonomi" wrote in message ... *sigh* this is REALLY a 'no-brainer'. Get *two* timers. That *is* great! I never thought of the removable tripper, so no on selected. Only problem is that the 7 day timers are pricey, aren't they? Again, good thinking. I had the two timers, you got the rest of it right. -- Jim in NC The 7 day timers can be found for under $20... Got one the other day. Now I just need the one day that runs as described. Intermatic makes one -- their model "TN311CL". It's called a "heavy duty appliance timer", rated for 15A. The Blue BORG (Lowes) sells it, here anyway, for $9.97. Comes with 3 green ("on") trippers, and 3 red ("off") ones. |
Similar Threads | ||||
Garmin 296 - Fuel Timer | Cockpit Colin | Piloting | 5 | November 19th 04 11:21 AM |
First timer wants soaring description | TravelMan | Soaring | 15 | October 17th 04 08:11 PM |
simple IFR timers | Matt Whiting | Instrument Flight Rules | 21 | June 5th 04 02:26 PM |
Approach Timer Frustration | Andrew Sarangan | Instrument Flight Rules | 12 | January 16th 04 11:04 PM |
Vietnam era F-4s Q | Ed Rasimus | Military Aviation | 87 | September 27th 03 03:59 PM |
