Mystery holes.
Old December 24th 08, 11:27 PM posted to rec.aviation.piloting
Monk
Default Mystery holes.
I stumbled across this earlier today. Below is the quote and link to
picture.
Although I've seen several areas with similar holes, this particular
set is right next to Bastrop Bayou, near the bridge where CR 227
crosses over it. Approximate lat/long is N29.094 W95.290.
Usually the holes are near a body of water: a river, stream, bayou,
canal, etc. And they are always water filled.
Any ideas?
http://www.texas-flyer.com/LightFlyer/holes.jpg
Old December 25th 08, 11:08 AM posted to rec.aviation.piloting
On Dec 24, 4:27*pm, Monk wrote:
I stumbled across this earlier today. *Below is the quote and link to
picture.
Any ideas?
Bombing practice in earlier years ?? It is weird though.... IMHO
Old December 25th 08, 03:08 PM posted to rec.aviation.piloting
Paul kgyy
picture.
Any ideas?
Could be geologic sinkholes? Underlying limestone dissolves in acid-
bearing water and caves in underneath?
Old December 25th 08, 04:50 PM posted to rec.aviation.piloting
Mxsmanic
Monk writes:
picture.
Any ideas?
Sinkholes, areas where the ground at the surface has collapsed downwards due
to underground erosion or subsidence.
Old December 25th 08, 05:11 PM posted to rec.aviation.piloting
a[_3_]
picture.
Any ideas?
These look remarkably like what one sees when when is culturing
bacteria on a petri dish, except on a different scale. It would appear
the only difference is vegetation is not growing in the 'hole' -- it
seems to be defined by an absence of leaves, rather than something
going on under the surface. I'd suspect some kind of leaf eating
insect, or an underwater plant that deprives the floating ones of
roots.
If you look at growth in the deserts, you see pretty much the opposite
of this -- cactii grow spaced because their roots spread out and
prohibit other plants from growing nearby by depriving them of water.
SInkholes would seem unlikely to affect growth on the surface.
Old December 25th 08, 05:40 PM posted to rec.aviation.piloting
Steve Hix
In article
picture.
Any ideas?
roots.
More than that, some cactus and other desert plants secrete chemicals
that actively suppress seed germination of potential competitors.
Old December 25th 08, 06:53 PM posted to rec.aviation.piloting
Monk
On Dec 25, 12:40*pm, Steve Hix
In article
picture.
Any ideas?
the only difference is vegetation is not growing *in the 'hole' -- it
seems to be *defined by an absence of leaves, rather than something
going on under the surface. *I'd suspect some kind of leaf eating
roots.
Very interesting theories.
Monk
Old December 25th 08, 08:43 PM posted to rec.aviation.piloting
Viperdoc[_6_]
due
A true genius in his own mind- so helpful and beneficent.
Old December 26th 08, 01:01 AM posted to rec.aviation.piloting
Terry
I suspect the holes are abandoned oil wells from long ago. Nothing left
but the damage from bringing up the "substrate" to the surface.
Limestone, oil soaked earth etc that no plant can grow in or at least is
favorable to the local vegetation.
That whole area around Galveston is riddled with those holes. I
understand years ago that area had hundreds of oil wells in a few block
area.
Thats my guess!
Terry
"Monk" wrote in message
picture.
Any ideas?
Old December 26th 08, 06:46 AM posted to rec.aviation.piloting
Frank Olson
area.
Thats my guess!
Terry
I disagree. I suspect that the "pilot" at the controls of the UFO that
did this was a student and was practicing "touch and go's". :-)
Covering holes [email protected] Soaring 9 May 2nd 08 05:57 PM
Tube Fuse Oil Holes John[_17_] Home Built 8 March 21st 08 12:11 PM
When Poorboys drill holes ...was: Drilling holes in steel tubing wright1902glider Home Built 4 November 4th 05 01:19 AM
Drilling holes in steel tubing wright1902glider Home Built 20 October 9th 05 03:43 AM
Filling Holes AKperson Owning 1 July 20th 05 03:54 PM
