Parallel Track function in GPS?
Old April 26th 04, 07:15 PM
Roy Smith
Default Parallel Track function in GPS?
Yesterday I played with the parallel track function in the CNX-80 for
the first time. I was introducing the CNX-80 to a student and I had
planned a VFR flight via airways. My student (rightfully) questioned
the wisdom of an over-water segment, so we decided to fly that segment
on a 5-mile offset parallel track (it got us over land and was a good
excuse to explore a software function I'd never used before).
But, here's my question. Why is it in the box to begin with? Other
than the gee-wiz marketing value, is there any real practical reason for
it existing?
VFR, we didn't need it (it was easy enough to follow the coastline
visually). IFR, it would have put us outside the airway boundary, so
it's probably not very useful there either. Is "fly parallel to V157
offset 2 miles to the left" something that I might ever expect to get in
an IFR clearance if I file /G ?
Old April 26th 04, 07:41 PM
Barry
Is "fly parallel to V157 offset 2 miles to the left" something
that I might ever expect to get in an IFR clearance if I file /G ?
One of the concerns with GPS is that the great accuracy can sometimes increase
the probability of a midair collision compared to conventional nav. Consider
two aircraft traveling on the same route in opposite directions at different
altitudes, in non-radar airspace. If, due to a pilot or controller error,
both planes end up at the same altitude, the probability that they would hit
was quite small with VOR, but much higher with GPS. Some airline pilots have
already started flying lateral offsets on their own, and ICAO is studying the
issue and trying to come up with standards. One of the proposed criteria is
that the procedure be transparent to the controllers. So it's unlikely that
ATC will ever assign a clearance to fly an offset, but at some point pilots
might be permitted or required to fly an offset on some routes.
Old April 29th 04, 12:15 PM
tscottme
Barry wrote in message
news
increase
Consider
different
error,
would hit
pilots have
studying the
criteria is
unlikely that
pilots
This FMS/GPS-assisted mid-air risk is what I have seen discussed in
numerous big-iron forums and an ALPA magazine. In both places the
discussion seemed to favor a small offset, say 1 mile right of
centerline, to avoid nose to nose meetings.
Scott
Old April 26th 04, 07:57 PM
Judah
Hi Roy,
I seem to recall the CNX-80 Tutorial talks about it being used for
weather avoidance during IFR enroute flight. I guess their thought is
that you can use it to request a diversion around weather, eg: a 5-mile
diversion to the left. Then you can program it into the CNX-80 and stay
parallel to your track.
As you know, I don't have a whole lot of IFR experience - I had thought
that you typically tell ATC about your diversions for weather in degrees
and time (5 degrees left for about 5 min), so it very well may be one of
those "sex-sells" types of features. But I thought I'd share with you
what I read on the tutorial...
Roy Smith wrote in
for it existing?
Old April 26th 04, 08:10 PM
Roy Smith
Judah wrote:
Hi Roy,
Hi Judah!
What you said sounds reasonable. Whenever I've wanted to alter course
for weather, I have indeed made my request/report in terms of heading,
but that's mostly because that's what's been the most convenient in the
pre-GPS days (if the only tool you've got is a hammer, everything looks
like a nail). I suppose now that I've got the tool, "I'd like to offset
5 miles left of course for weather" might work just as well.
Old April 26th 04, 11:28 PM
Ben Jackson
That's exactly what the manual for the old Apollo LORAN 604 says
regarding PTK on the LORAN. You'd think they could come up with a
second use for it by now!
As far as I know PTK for GPS just keeps those $900 annunciator/switch
makers in business.
Ben Jackson
http://www.ben.com/
Old April 27th 04, 01:13 AM
Tarver Engineering
"Ben Jackson" wrote in message
news:U1gjc.26305$cF6.1144747@attbi_s04...
makers in business.
The big boys with their INS have it, why shouldn't you?
Old April 27th 04, 01:26 PM
And, it was never used, either.
Old April 27th 04, 01:42 AM
kage
If you are flying in RVSM airspace, like across the Atlantic in the "tracks"
and you have certain types of emergencies, ATC wants you to parallel the
course 30 miles off to the right. That's one reason.
Karl
it existing?
Arlington NASCAR track dead? Rich S. Home Built 51 December 8th 04 03:34 AM
The battle for Arlington Airport begins? Paul Adriance Home Built 45 March 30th 04 11:41 PM
how I map my flights Snowbird Instrument Flight Rules 10 November 30th 03 11:26 PM
Using Excel or Access to keep track of students/records? BoDEAN Instrument Flight Rules 5 October 2nd 03 05:07 AM
Downloading GPS track data and overlaying charts John Galban Instrument Flight Rules 2 July 25th 03 03:15 PM
