JPI EGT probe failure typical signs
My #3 EGT usually works just fine but every once in a while it will
jump up to an unreasonable number or even just report "OPEN PROBE" on the screen. It may do this for several minutes and then just come back and work just fine. JPI says to first swap it with another (#1 EGT) and see if its the probe. However, if I'm going to go out to the airport, put on my grubbies, decowl the plane, etc and there is a say 60% chance the problem is the probe, I'd rather just buy a new probe and try that right away. Does having the probe go on and off line during flight a typically failure method for JPI EGT probes? -Robert |
"Robert M. Gary" wrote:
Does having the probe go on and off line during flight a typically failure method for JPI EGT probes? I don't have a problem with my JPI EGT probes, but I have been experiencing similar, intermittent problems with my JPI RPM probe/connection/??? over the last year. This shows up as a sudden drop of the RPM on my EDM800 down to zero, then back up, or down to some unreasonable level, such as 1200, then back up perhaps ten minutes later. The mechanic has checked the connections twice and replaced the wire once but it still is happening. Either it is vibrating loose or perhaps the TKS anti-ice fluid that I have been running all winter is corroding the connection? -- Peter |
Robert M. Gary wrote:
My #3 EGT usually works just fine but every once in a while it will jump up to an unreasonable number or even just report "OPEN PROBE" on the screen. It may do this for several minutes and then just come back and work just fine. JPI says to first swap it with another (#1 EGT) and see if its the probe. However, if I'm going to go out to the airport, put on my grubbies, decowl the plane, etc and there is a say 60% chance the problem is the probe, I'd rather just buy a new probe and try that right away. Does having the probe go on and off line during flight a typically failure method for JPI EGT probes? -Robert EGT probes, of any type, provide very small (millivolt) signals to the gauge itself. I recently had a devil of a time with an Insight system exhibiting symptoms similar to yours. DVM showed good output and good insulation, but indeed there were several, almost microscopic, insulation cracks near the probe. In flight, under vibration, the wire was shorting to airframe ground. Rip |
It MIGHT be the probe but it is more typical of a bad crimp joint in a
connector somewhere in the circuit to the probe. On 1 Mar 2006 16:16:47 -0800, "Robert M. Gary" wrote: My #3 EGT usually works just fine but every once in a while it will jump up to an unreasonable number or even just report "OPEN PROBE" on the screen. It may do this for several minutes and then just come back and work just fine. JPI says to first swap it with another (#1 EGT) and see if its the probe. However, if I'm going to go out to the airport, put on my grubbies, decowl the plane, etc and there is a say 60% chance the problem is the probe, I'd rather just buy a new probe and try that right away. Does having the probe go on and off line during flight a typically failure method for JPI EGT probes? -Robert |
Check the plug on the back of the EDM unit also - it's possible to
jiggle things loose back there. I had my OAT probe go off line after the annual a while back; the mechanic had knocked the wire loose while working on avionics. |
No experience with JPI. But on my EI, each probe could be unpluged
from the scaner. I had problem with #6 once. I unpluged #6 & 4, and pluged #6 probe to #4 on scaner, and #4 to #6 on scaner. Fly it & now problem is #4 in the scaner & #6 probe. Ordered & changed probe in #6, & everything is fine. |
Similar Threads | ||||
I want to build the most EVIL plane EVER !!! | Eliot Coweye | Home Built | 237 | February 13th 06 03:55 AM |
Most reliable homebuilt helicopter? | tom pettit | Home Built | 35 | September 29th 05 02:24 PM |
CHT probe + resistor installed (final) | Jim Burns | Owning | 8 | September 10th 05 02:34 PM |
Mini-500 Accident Analysis | Dennis Fetters | Rotorcraft | 16 | September 3rd 05 11:35 AM |
TSA requirement of Security Awareness Training | dancingstar | Piloting | 3 | October 5th 04 02:17 AM |
