Sunlight readable PNAs reviewed
Old December 31st 11, 03:10 AM posted to rec.aviation.soaring
PCool
Default Sunlight readable PNAs reviewed
There is an interesting discussion here at
http://www.postfrontal.com/forum/top...89&whichpage=6
with a lot of pictures I have taken out of new PNAs with 800-900 nits
displays.
This PNA has also a spare RS232. I am searching for a Dell Streak to
compare, but it is was gone out of production a few months ago.
With the sun in front of us, and not in the back, brightness is the only
help to make the screen visible at all.
I am also about to review the Holux 61CS, which is a long awaited unbranded
device with a very good visibility.
(I dont sell them!)
paolo
Old December 31st 11, 01:37 PM posted to rec.aviation.soaring
Richard[_9_]
On Dec 30, 7:10*pm, "PCool" wrote:
There is an interesting discussion here athttp://www.postfrontal.com/forum/topic.asp?TOPIC_ID=5589&whichpage=6
displays.
This PNA has also a spare RS232. *I am searching for a Dell Streak to
(I dont sell them!)
paolo
I think the following exerpt from a Gliding Internation Article may
clear up many misconceptions that high brightness makes a display
sunlight readable. Brightness minimually affects the sunlight
readability. Contrast ratio is the most important factor.
The Craggy Aero Ultimate Le aviation quality display sets the standard
in sunlight readability it delivers a radically high level of screen
brightness that results in unparalleled picture sharpness and
vividness. The VHB LED backlight in the LCD module consumes only 4.5
Watts at full brightness. The LCD screen temperature is quite small
and there are few thermal management issues. The LCD module displays
a VGA (640 x 480) image.
Contrast ratio is the most important factor in high and full sunlight
applications. Contrast ratio of a display is defined as the luminance
(brightness) ratio between a brighter state and a darker state. The
color LCDs “white” state and “black” state are used to calculate the
contrast ratio.
Contrast ratio = CR = luminance of the “white” /luminance of the
“black”.
If white and black are equally bright, then CR = 1 and the display is
not readable. Due to the coatings applied to the display the contrast
ratio of the Ultimate Le is extremely high. The high contrast ratio
makes the view in direct sunlight only slightly dependent on the
backlight intensity. Even at the low backlight setting the display
is totally readable in full sunlight. These characteristic contribute
to the overall superior direct sunlight performance in the cockpit.
No longer do you need to run software in the white or no terrain mode,
the color and clarity are vibrant in full sun.
http://www.craggyaero.com/ultimate_le.htm
Richard
www.craggyaero.com
Old January 1st 12, 09:31 AM posted to rec.aviation.soaring
John Galloway[_1_]
At 13:37 31 December 2011, Richard wrote:
athttp://www.postfrontal.com/foru=
m/topic.asp?TOPIC_ID=3D5589&whichpage=3D6
900 nits
displays.
This PNA has also a spare RS232. =A0I am searching for a
Dell Streak to
ago.
the only
awaited
unbrand=
ed
(I dont sell them!)
paolo
may
display
standard
consumes only 4.5
small
module displays
sunlight
luminance
The
color LCDs =93white=94 state and =93black=94 state are
used to calculate
th=
e
contrast ratio.
Contrast ratio =3D CR =3D luminance of the =93white=94
/luminance of the
=93black=94.
If white and black are equally bright, then CR =3D 1 and the
display is
contrast
ratio
display
contribute
cockpit.
terrain mode,
Richard
www.craggyaero.com
Why don't other non-touch-screen glider computer instrument
makers use the same screens as the Ultimate?
BTW - the new Butterfly vario (if it works as claimed it could be
a significant advance in variometry) + the Craggy Ultimate looks
like a great combination matching all the features of a fully
optionalised LX 9000.
John Galloway
Old January 1st 12, 10:47 AM posted to rec.aviation.soaring
PCool
Gentlemen, the sunlight readable screen I (and many people out here) want to
buy should not be expensive!
A 500 euro device is too much, and way too much a 1000 euro. These should be
portable devices.
A great deal of people is buying cheap but usable PNAs such as the MIO400
(60 euro, new not refurbished), with serial port and internal gps.
The devices we mention on the forum share the same price range: the 900 nits
one, 5 inches 800x480 with serial port is sold in the UK for 275 euro.
Most people want a device sized between 4 and 6 inches. We all know that 7
inches and more becomes a big problem to be installed aboard.
This is why most of PNAs are sized 4.3 and 5 inches. Bigger LCD will not
fit easily (and costly) rack mounted.
Manufacturers are improving LCD coating process, brightness and contrast
ratio, to provide cheap devices.
Of course if you want and can spend more, LX 9000, Craggy Aero Ultimate,
Triadis, there are several great choices!
heppy 2012 everybody
paolo
"John Galloway" ha scritto nel messaggio
.com...
900 nits
displays.
Dell Streak to
ago.
the only
awaited
unbrand=
ed
(I dont sell them!)
paolo
may
display
standard
consumes only 4.5
small
module displays
sunlight
luminance
The
used to calculate
th=
e
contrast ratio.
/luminance of the
=93black=94.
display is
contrast
ratio
display
contribute
cockpit.
terrain mode,
Richard
www.craggyaero.com
John Galloway
Old January 6th 12, 01:02 AM posted to rec.aviation.soaring
brianDG303[_2_]
portable devices.
Most people want a device sized between 4 and 6 inches. *We all know that 7
This is why most of PNAs are sized 4.3 and 5 inches. *Bigger LCD will not
Of course if you want and can *spend more, LX 9000, Craggy Aero Ultimate,
paolo
"John Galloway" ha scritto nel messaggionews:4f002b1f$0$30185$a8266bb1@newsreader .readnews.com...
900 nits
displays.
Dell Streak to
ago.
the only
awaited
unbrand=
ed
(I dont sell them!)
paolo
may
display
sunlight readable. *Brightness minimually affects the sunlight
readability. *Contrast ratio is the most important factor.
standard
vividness. * The VHB LED backlight in the LCD module
consumes only 4.5
small
and there are few thermal management issues. *The LCD
module displays
sunlight
applications. *Contrast ratio of a display is defined as the
luminance
The
used to calculate
th=
e
contrast ratio.
/luminance of the
=93black=94.
display is
not readable. *Due to the coatings applied to the display the
contrast
ratio of the Ultimate Le is extremely high. * The high contrast
ratio
backlight intensity. * Even at the low backlight setting the
display
is totally readable in full sunlight. *These characteristic
contribute
cockpit.
terrain mode,
Richard
www.craggyaero.com
like a great combination matching all the features of *a fully
John Galloway
having flown last year with a LXminimap and the connected vario, I
think people are missing a large safety and convenience issue by
concentrating on sunlight visibility and not the total user
interface. The eyes-in-the-cockpit time required to use a touchscreen
to move between maps and pages, scroll through turnpoints, select a
new turnpoint, and return to the original screen is several to 20
times longer than when using a well set up stick controller or other
remote control device. The operation described can be accomplished
with a single button press and a glance with the LX stick controller.
In my mind this is as important as sunlight visibility.
Old January 6th 12, 01:58 AM posted to rec.aviation.soaring
Mike[_37_]
portable devices.
paolo
900 nits
displays.
Dell Streak to
ago.
the only
awaited
unbrand=
ed
(I dont sell them!)
paolo
may
display
standard
consumes only 4.5
small
module displays
sunlight
luminance
The
used to calculate
th=
e
contrast ratio.
/luminance of the
=93black=94.
display is
contrast
ratio
display
contribute
cockpit.
terrain mode,
Richard
www.craggyaero.com
John Galloway
interface. *The eyes-in-the-cockpit time required to use a touchscreen
remote control device. *The operation described can be accomplished
LX Minimap and the vario is a very nice set up. My thoughts on the
Streak with XCSoar is - moving through various pages or screens with
XCSoar requires a finger swipe to the left or right depending on what
screen you are looking for -there are eight that can, when once set
up, be accessed easily with swipes. Selecting a new turn point on
the fly is as simple as touching the turn point location on the moving
map, and acknowledging it when the turn point info window comes up on
the screen, by pressing "GoTo". Takes a couple of seconds. Making a
new contest task from scratch, on the fly, is a bit of a chore
though, and probably is with any soaring program. Changing a task from
the task file takes about 15 seconds.
Old January 8th 12, 02:10 AM posted to rec.aviation.soaring
akiley
portable devices.
one, 5 inches 800x480 with serial port is sold in the UK for 275 euro..
paolo
900 nits
displays.
Dell Streak to
ago.
the only
awaited
unbrand=
ed
(I dont sell them!)
paolo
may
display
standard
consumes only 4.5
small
module displays
sunlight
luminance
The
used to calculate
th=
e
contrast ratio.
/luminance of the
=93black=94.
display is
contrast
ratio
display
contribute
cockpit.
terrain mode,
Richard
www.craggyaero.com
John Galloway
LX Minimap and the vario is a very nice set up. *My thoughts on the
up, *be accessed easily with *swipes. Selecting a new turn point on
the screen, by pressing "GoTo". *Takes a couple of seconds. *Making a
new contest task from scratch, on the fly, *is a bit of a chore
I use XCSoar with a Droid phone and a bluetooth GPS (45 USD). I rent
and don't own a ship. XCSoar switches modes automatically. So you
can design your own set of data fields (infoboxes) for cruise, thermal
and final glide. So you seldom need to swipe. It even has auto MC,
so you don't have to fiddle with MC. Use it in sim mode, or with
Condor on the ground to get proficient and this greatly reduces fidget
time in the cockpit. The team at XCSoar has really brought this app a
long way and it's still being imporved at a fast pace.
I personally think it it very hard to evaluate these screens by
tossing them out in the sunlight and firing off a photo. In reality
most screens that do well in sunlight, do so not by the strength of
their backlight, (backlight can rarely compete with full sun) but by
there ability to "glow" and actually take advantage of direct sun.
Some of the old iPaqs do this, but there is a specific angle to the
sun that makes them glow brighter. Having these devices on a mount
with the ability to swivel them around really helps their
readability. Then some devices are not helped by sunlight and are
better shaded somehow. Fly under the shade of a cloud, and the whole
problem changes. Backlighting becomes a bigger factor. To complicate
it more, some devices like Oudie have a matt glass screen, where
others have glossy. The glossy reflects objects that can make the
screen hard to read, but they can also be angled toward dark objects
(like the black t-shirt I wear) which really makes the screen pop.
Matt screens don't have the annoying reflections, but they scatter
light and have a low contrast hazy look to them. Maybe better placed
in shade or hooded somehow.
The exception seems to be paying a lot of money for a navigator. A
Garmin 369 or 496 has very powerful backlighting. ... akiley
Oudie vs Streak sunlight readability Max Kellermann Soaring 14 July 7th 11 04:04 PM
Possible Solution for Daylight Readable Displays folken Soaring 0 September 15th 10 02:32 AM
Garmin iQue 3600a -- sunlight screen readability? Chuck Instrument Flight Rules 7 March 24th 05 10:00 PM
Garmin iQue 3600a -- sunlight screen readability? Chuck Piloting 17 March 24th 05 10:00 PM
Ed Rasimus Reviewed Cub Driver Military Aviation 1 August 13th 04 09:55 PM
