No, I think a short between P leads would kill the engine when put in either the
L or the R position. Grounding the P lead kills that mag, an open circuit lets the mag run. If you had a short, then grounding either mag would ground both. The problem is either a defective mag switch such that neither the L or R positions ground the respective mag, or the timing is way off. Art wrote: Another possible failure mode could be a short between the Right and Left P leads but not to ground. -- --Ray Andraka, P.E. President, the Andraka Consulting Group, Inc. 401/884-7930 Fax 401/884-7950 http://www.andraka.com "They that give up essential liberty to obtain a little temporary safety deserve neither liberty nor safety." -Benjamin Franklin, 1759 |
Similar Threads | ||||
RPM drop and "popping" sound on mag check, C-172 | C Kingsbury | Owning | 7 | September 14th 04 11:06 AM |
Changes in Instrument Proficiency Check Requirements | Richard Kaplan | Instrument Flight Rules | 71 | June 10th 04 08:02 PM |
Use of hand-held GPS on FAA check ride | Barry | Instrument Flight Rules | 1 | August 9th 03 09:25 PM |
check your tachometer | Robert Scott | Owning | 1 | August 4th 03 06:28 PM |
check your tachometer | Robert Scott | Home Built | 0 | August 4th 03 05:05 PM |
