A Call to Arms from Richard VanGrunsven
Old March 8th 08, 01:19 PM posted to rec.aviation.homebuilt,rec.aviation.piloting
Acepilot
Default A Call to Arms from Richard VanGrunsven
No repairman's certificate (not a "right" but a "priviledge").
WJRFlyBoy wrote:
You just can't buy one and have the same privilges as the original builder.
Jim Pennino
Ok, what rights do I lose and why do I lose them?
  #72
Old March 8th 08, 01:23 PM posted to rec.aviation.homebuilt,rec.aviation.piloting
Acepilot
I agree. On one of Van's promotional videotapes, there's a comment that
one guy built "3 RV-3s and yes, an RV-4." Did the second and third
RV-3s not cert airworthiness certificates?
Morgans wrote:
"cavelamb himself" wrote
Actually, jst to keep the record straight, you CAN buy an X-AB airplane.
But the biulder can not build and register another of the same kind.
Really? Where did you get that information? Do you know of a case where a
builder was denied the second airplane's airworthiness permit?
  #73
Old March 8th 08, 01:25 PM posted to rec.aviation.homebuilt,rec.aviation.piloting
Acepilot
That's not the way I understand it (an the question has been asked to
EAA as well). I own an experimental that I didn't build. I can do any
maintenance and/or mod I want. The only thing I can't do is the yearly
condition inspection.
Scott
Bertie the Bunyip wrote:
WJRFlyBoy wrote in
On Sat, 08 Mar 2008 06:45:03 GMT, wrote:
In rec.aviation.piloting WJRFlyBoy
Yet I can't buy a completely built kit/plans plane.
Sure you can.
See any airplanes for sale web site.
builder.
Jim Pennino
the origianl builder is the manufacturer. He can effect any maintenance
or repeair on the airplane he likes...You buy it , you can't.
Th ereason is pretty obvious. He has demonstrated he knows what he is
doing and has effectively been issued a resticted airframe or airframe
and powerplant licence.
Bertie
  #74
Old March 8th 08, 02:50 PM posted to rec.aviation.homebuilt,rec.aviation.piloting
Bertie the Bunyip[_25_]
Acepilot wrote in
OK, my bad....
Bertie
  #75
Old March 8th 08, 02:54 PM posted to rec.aviation.homebuilt
badbaz
On Fri, 07 Mar 2008 20:50:55 -0500, Sliker wrote:
You still building Roger? I can second the build time for the Glasair
3, I'm 17 years and still going on my 3. The Glasair 3 from that era
would never have any problem with the 51 % rule. It's got to be one of
the most labor intensive homebuilts out there. And once I started
building, it became obvious the parts the factory makes are the easy
stuff. laying up big stuff in molds and popping them out after they
cure. Probably the best part of the kit is having most, but not all,
of the hardware and metal parts assembled and done. Like the landing
gear. Glad I don't have to weld up gear legs, like someone building a
Barracuda or similar project. Actually, there are lots of plans built
planes out there I could have finished years ago.
Rich
On Fri, 07 Mar 2008 19:06:44 -0500, Roger
On Fri, 07 Mar 2008 00:03:24 -0600, cavelamb himself
Jim Logajan wrote:
Jim Logajan wrote:
The FAA is about to make it a whole hell of a lot harder for people to
build safe amateur built aircraft. Richard VanGrunsven, founder of one
of the most successful kit aircraft companies, has written up a
warning and a call to arms about the issue. You can read it beginning
on page 3 of this document:
http://doc.vansaircraft.com/RVator/2...008-RVator.pdf
Also consider using this site (to save Vans Aircraft some bandwidth load):
http://www.vansairforce.net/rvator/1-2008-RVator.pdf
Sounds more like they want to make it harder to_have_one_built_for_you.
That is the reasoning behind all this, but as with many regulations
it's going to take some close watching to keep them from going astray.
In the past, there really wasn't a 51% rule as we think of it. They
expected the builder complete 51% of the tasks. IOW, if you
constructed one aileron That was as good as constructing and mounting
both. Build one rib is as good as building 30. Some areas are just
done much better by the manufacturer as stated in the letter. forming
ribs as an example. In the past IIRC you could share the wing,
aileron, elevator and stab construction with the manufacturer if they
stamped out the ribs and you put everything together. The FAA
apparently wants to eliminate this. How they would go about it and how
it would affect what we do is really an unknown at this point.
There's a big gap between the *Intent* of the rule as has been
interpreted AND ACCEPTED by the FAA and the *Letter* of the rule.
In my G-III the fuselage shells (right, and left, along with the
forward and rear belly pans are factory molded composite sandwiches.
The builder spends many hours just jigging, aligning, and bonding
these sections. The horizontal stab comes with pre molded ribs and
shear webs (which have to be cut to size) along with the upper and
lower shells, but putting one together is a long and tedious task.
OTOH the elevator, ailerons, and flaps only come as shells. You get
to figure out the dimensions of the ribs. They give a bit of guidance
on the lay ups but absolutely nothing on the dimensions or shaping of
those ribs.
The G-III is probably one of the most, if not the most labor intensive
kit out there at a conservative 4000 hours for construction. Few make
it in that little a time.. Even the fast build (Jump start in their
dictionary) still takes thousands of hours to complete.
there is a good chance the way they are wording some things that even
this kit might be affected.
These articles explain the FAA's concerns over excessive commercial
abuses of the Experimental Amateur Built (E-AB) licensing category.
The ARC committee was created as an FAA/EAA/ Industry process to address
the FAA concerns and to recommend corrective actions.
Unfortunately as logical as that sounds it doesn't necessarily follow
that any rules changes will be as logical. Even as currently written
changing from the Intent to the letter of the rule would be a drastic
change.
I doubt with what I'm building if the rules changes would have much
effect. OTOH contrary to probably most on the group, I see little
problem or even downside to changing it to a 20 or 25% rule. I happen
to like building and by doing so I can also end up with a plane that
has capabilities not available in production aircraft AND end up with
one I couldn't afford to purchase outright. OTOH I have no problem
nor do I see a problem with some one hiring the same plane built for
them as long as it still has to abide by the flight restrictions of
other E-AB aircraft.. I say this for two reasons that are very
apparent to me.
Although many of us build for the fun of it (education is rarely one
of the top reasons, or even one of the reasons.) From what I've seen
and we have quite a few homebuilts at 3BS (kit and scratch built),
most are constructed either to save money or just because they like to
build. One more reason is they couldn't purchase a plane like they
want to build even if they did have the money and we have quite a few
who are flying two and even three engine jets.OK only one is flying a
three holer.
Yes I'm learning things and some would call that education which it
is, but I'll state outright, that has nothing to do with me building.
I'm building because I like to do it! I'd get more enjoyment out of
building another because I could do it more efficiently, faster, and
cheaper. HOWEVER if I ever do get the thing finished and I'm able to
fly it, my main/only reason for building at that time would be "flying
an airplane I constructed myself".
www.rogerhalstead.com
Being an old fart I remember when Cessna, Piper &co. nearly went belly up
due to ambulance chasers. Cessna even shut down its production lines for
piston aircraft because of it. this is where the expermentals saved their
collective bacons as the lawyers found that individuals didn't have big
cheque books to raid. Cessna only recommencet production after congress
changed the litigation laws, now if become a pro builder to the lawyers you
are a manufactures so whach out!
  #76
Old March 8th 08, 03:46 PM posted to rec.aviation.homebuilt,rec.aviation.piloting
cavelamb himself[_4_]
That was pretty common interpretation of this mess when I was a kid.
Back when FAA was doing "pre-close" inspections, they were a lot more
involved in the process.
  #77
Old March 8th 08, 03:58 PM posted to rec.aviation.homebuilt,rec.aviation.piloting
Blueskies
"cavelamb himself" wrote in message ...
Ahhh, back in the days before entitlements really started sinking our govment and we truly received services...
  #79
Old March 8th 08, 06:16 PM posted to rec.aviation.homebuilt,rec.aviation.piloting
Blueskies
The original builder can do any maintenance or modification he desires
while the buyer has to follow the same rules as if he had bought a
Cessna or Piper.
Not true...
  #80
Old March 8th 08, 06:35 PM posted to rec.aviation.homebuilt,rec.aviation.piloting
Cessna or Piper.
Not true...
Yeah, in retrospect I realized that.
Without multiple pages of details, the purchaser of a home built can
do less than the builder, but more than the buyer of a Cessna.
Jim Pennino
Remove .spam.sux to reply.
A Call to Arms from Richard VanGrunsven Jim Logajan Piloting 181 May 1st 08 03:14 AM
Flew home and boy are my arms tired! Steve Schneider Owning 11 September 5th 07 12:16 AM
ASW-19 Moment Arms jcarlyle Soaring 9 January 30th 06 10:52 PM
[!] Russian Arms software sale Naval Aviation 0 December 18th 04 05:51 PM
Dick VanGrunsven commutes to aviation Fitzair4 Home Built 2 August 12th 04 11:19 PM
