GNS430 on the Airway
Old February 9th 06, 12:59 PM posted to rec.aviation.ifr
Default GNS430 on the Airway
Matt Barrow wrote:
"Peter R." wrote in message
Hmmm...how are they going to route traffic when all the VOR's are
decommissioned in the next few years?
Who told you that?
Old February 9th 06, 01:15 PM posted to rec.aviation.ifr
wrote...
Who told you that?
http://www.faa.gov/asd/gpstrans.pdf
http://avnwww.jccbi.gov/icasc/PDF/frp1999.pdf
http://www.alaska.faa.gov/capstone/d...de%20v1.1H.pdf
Old February 9th 06, 01:20 PM posted to rec.aviation.ifr
"Ted" wrote in message
et...
wrote...
Who told you that?
also see:
http://gps.faa.gov/
http://www.navcen.uscg.gov/cgsic/mee...ons/Hanlon.ppt
Old February 9th 06, 04:05 PM posted to rec.aviation.ifr
"Ted" wrote:
wrote...
Who told you that?
Don't use outdated FRPs. The FAAs OLD thought of getting rid of all
ground-based navaids in favor of SATNAV was flawed from the beginning.
It was further reduced to outdated after 9/11.
Ron Lee
Old February 9th 06, 04:09 PM posted to rec.aviation.ifr
"Marco Leon" mmleon(at)yahoo.com wrote:
So how far off an airway is an aircraft when they are following a GPS flight
plan with every intersection and VOR? Is there an article or study somewhere
that includes metrics to back it up? For example, "a non-WAAS GPS-derived
line direct btween two intersection xx miles away will differ from the
airway between those same two intersections by x.x statute miles." How do
the error allowances play into this?
Since unaugmented GPS (not using WAAS) is accurate to 10 meters or so
(plus/minus) and an airway is plus/minus four MILES (or is is two?)
the navigation source (GPS) is not a major error source.
Ron Lee
Old February 9th 06, 04:48 PM posted to rec.aviation.ifr
An airway is 8 miles wide (4 miles on either side of the centerline).
One of the problems is that GPS accounts for magnetic variations differently
than the VORs do. Also I don't think GPS accounts for the fact that the
VOR radial are not exactly aligned with magnetic north (what is this called?
variance? I can't remember - it's documented in the A/FD).
GPS position errors would be on top of all this.
Ron Lee
Mark Hansen, PP-ASEL, Instrument Airplane
Cal Aggie Flying Farmers
Sacramento, CA
Old February 9th 06, 05:03 PM posted to rec.aviation.ifr
differently
called?
This would have an effect only if the procedure has you tracking a defined VOR
radial. There might be some such procedures, but I can't think of any at the moment.
All the airway segments (that's what we're talking about, right?) that I know of
have a defined point at each end of the segment. There is one and only one great
circle route between those two points. It's the same great circle whether you
follow it with a GPS or a VOR receiver.
Dave
Old February 9th 06, 06:05 PM posted to rec.aviation.ifr
"Ron Lee" wrote in message
"Ted" wrote:
wrote...
Who told you that?
Do you have a newer version?
How so?
  #29
Next few years? Where did you get this timeframe?
See Ted's posts further down the thread.
  #30
Old February 10th 06, 06:31 PM posted to rec.aviation.ifr
et...
wrote...
Who told you that?
also see:
http://gps.faa.gov/
The WAAS implementation in that first PDF (10 years old) is terribly out
of date. WAAS, although supporting LPV, is not performing as well as
they hoped when that was published.
There is still no sole-means en route in sight, except for Alaska, which
is an exception to the usual ICAO requirements.
Odd clearance -- airway given twice Roy Smith Instrument Flight Rules 15 September 20th 05 03:32 PM
GNS430 Installation Wayne Sweet Home Built 0 October 3rd 04 04:39 AM
B-RNAV with GNS430 Daniel Hofer Instrument Flight Rules 1 September 1st 04 04:12 PM
Wanted: Blank Datacard Garmin GNS430 Marco Leon Piloting 4 August 31st 04 06:20 PM
Wanted: Blank Datacard Garmin GNS430 Marco Leon Owning 3 August 31st 04 03:33 PM
