Slide-in Garmin GTX-320A
Old May 4th 07, 05:47 PM posted to rec.aviation.owning
Marco Leon
Default Slide-in Garmin GTX-320A
The KT-76A finally went tango uniform so I'm getting a Garmin GTX-320A with
the adapter for the King transponder. Actually, the KT-76A still works but
it takes 45 minutes to an hour for it to warm up so it's equivalent to dead.
Has anyone out there gone the slide-in replacement route on the Garmin? How
was the experience and did you have to get a new antenna (I have the
pole-type)? Lastly, was it a logbook entry or did you have to get an
avionics shop so do anything else besides the IFR transponder check? The W&B
seems to be negligible given the 1lb weight difference.
Thanks in advance.
Marco
Old May 4th 07, 06:55 PM posted to rec.aviation.owning
rq3[_2_]
I did a 320A slide-in replacement for an old Narco AT-50.
I replaced both the antenna and the coax, primarily because they were
of unknown age. The installation was painless and I filed a 337 and had
a transponder cert done to complete the process.
Rip
Thanks in advance.
Marco
Old May 4th 07, 09:20 PM posted to rec.aviation.owning
Marco Leon
"rq3" wrote in message
of unknown age. The installation was painless and I filed a 337 and had a
Rip
Did you file the 337 yourself or did you have a shop do it?
Old May 4th 07, 10:11 PM posted to rec.aviation.owning
Rip
Rip
I'm an A&P/IA. I did it myself.
Rip
Old May 6th 07, 02:05 AM posted to rec.aviation.owning
Curious to know... did you make this a field approval? So a fed
stamped box
3 on the 337? If not, what approved data did u use?
Around here, A&Ps are limited to installing ELTs. A real pain. I
have to get a shop to run all this thru... then they have little
problem.
A&Ps have no standing, even IAs.
I'm curious whether it's really different where you are.
Bill Hale Loveland CO
Rip
Rip
Slide in replacement for King KX170 Com Dico Owning 8 May 12th 06 05:32 AM
A-4 slide collection for sale TOPFLIGHTPICS Military Aviation 0 August 17th 04 10:02 PM
Cylinder Wrenches for 0-320A Narrow Deck DAVE Home Built 1 December 31st 03 01:45 PM
slide-in replacement for Cessna 300 series nav-com? Bill T. Owning 2 November 14th 03 10:47 PM
TKM MX-11 Com true slide replacement ? Rohit Fedane Owning 0 September 21st 03 05:02 PM
