garmin g600
anyone using one? what are your thoughts and impressions?...
thanx richard colorado |
garmin g600
On Aug 21, 1:40*pm, "~^ beancounter ~^" wrote:
anyone using one? what are your thoughts and impressions?... thanx richard colorado I considered it as part of my panel upgrade but went with the Aspen Evolution 1000 system - you get most of the benefits of glass for a LOT less money. I had bought the plane with a Garmin 530W so already had a good nav panel. http://www.aspenavionics.com/index.p...s/efd1000-pro/ The Garmin might make sense if you're doing a fresh start on a total panel rebuild, starting with 1960s avionics throughout. |
garmin g600
our partners are l@@kin' at Aspen products as well...
more bang for the buck..ea? richard colorado ps: we may wait a year or two for the next generation 3d units to come down a bit in price......not sure yet.... On Sep 6, 10:53*am, Paul kgyy wrote: On Aug 21, 1:40*pm, "~^ beancounter ~^" wrote: anyone using one? what are your thoughts and impressions?... thanx richard colorado I considered it as part of my panel upgrade but went with the Aspen Evolution 1000 system - you get most of the benefits of glass for a LOT less money. *I had bought the plane with a Garmin 530W so already had a good nav panel. http://www.aspenavionics.com/index.p...s/efd1000-pro/ The Garmin might make sense if you're doing a fresh start on a total panel rebuild, starting with 1960s avionics throughout. |
garmin g600
I primarily wanted backup for the vacuum AI and HI and the Aspen
provides both. I also wanted GPSS and that's built into the Aspen unit as well. Using solid state gyro technology also had a lot of appeal, rather than doing a duplicate mechanical gyro except electrically driven. Besides all that, you get a full HSI and RMI built in, as well as the center section that provides TAS, OAT, and winds aloft. Hard to beat in a 10K package. |
garmin g600
true dat..... ‹(•¿•)›
" Hard to beat in a 10K package " On Sep 9, 8:15*am, Paul kgyy wrote: I primarily wanted backup for the vacuum AI and HI and the Aspen provides both. *I also wanted GPSS and that's built into the Aspen unit as well. *Using solid state gyro technology also had a lot of appeal, rather than doing a duplicate mechanical gyro except electrically driven. Besides all that, you get a full HSI and RMI built in, as well as the center section that provides TAS, OAT, and winds aloft. Hard to beat in a 10K package. |
garmin g600
----------------ann news snip--------------------------------
The Garmin G600 was first unveiled at AirVenture 2006, as ANN reported. Cutter calls the retrofit panel a perfect solution for owners looking for the enhanced situational awareness, pilot workload reduction and safety that a glass cockpit provides without the need of upgrading to a completely new aircraft. Contained within the space of a standard "six-pack" of primary flight instruments, the two 6.5-inch diagonal flat-panel LCDs of the G600 allows for an easy upgrade to a glass cockpit without costly and time-consuming major panel redesigns or replacement. The Garmin G600 offers a crisp and clear VGA quality display that's fully readable in direct sunlight thanks to Garmin's advanced RGB backlight system. Replacing gyro-based mechanical instruments, the left-hand panel offers an EFIS-like Primary Flight Display for attitude, airspeed, climb rate, altitude and course/heading information. The right-hand panel serves as the Multi-Function display providing a wide range of data from navigational overlays to weather data. Such a combination allows owners to experience a "big picture" suite of avionics without replacing their beloved aircraft. Cutter says that depending on your panel configuration, installation time can be as little as two weeks from start to finish for the G600 upgrade. FMI: www.garmin.com, www.cutteraviation.com On Sep 9, 9:53*am, "~^ beancounter ~^" wrote: true dat..... * * * ‹(•¿•)› " Hard to beat in a 10K package " On Sep 9, 8:15*am, Paul kgyy wrote: I primarily wanted backup for the vacuum AI and HI and the Aspen provides both. *I also wanted GPSS and that's built into the Aspen unit as well. *Using solid state gyro technology also had a lot of appeal, rather than doing a duplicate mechanical gyro except electrically driven. Besides all that, you get a full HSI and RMI built in, as well as the center section that provides TAS, OAT, and winds aloft. Hard to beat in a 10K package.- Hide quoted text - - Show quoted text - |
garmin g600
I did ask about the G600 at my installer before installing the Aspen
unit. He estimated about $35AMU for the G600 vs 13 for the Aspen. |
garmin g600
On Thu, 11 Sep 2008 14:16:40 -0700 (PDT), Paul kgyy
wrote: I did ask about the G600 at my installer before installing the Aspen unit. He estimated about $35AMU for the G600 vs 13 for the Aspen. Before looking at just raw numbers get an apple-to-apples comparison. Yes, G600 will cost much more, but it's also a significantly different platform than the aspen. |
garmin g600
"Peter Clark" wrote in message
... On Thu, 11 Sep 2008 14:16:40 -0700 (PDT), Paul kgyy wrote: I did ask about the G600 at my installer before installing the Aspen unit. He estimated about $35AMU for the G600 vs 13 for the Aspen. That sounds like the Aspen PFD only for that price. Before looking at just raw numbers get an apple-to-apples comparison. Yes, G600 will cost much more, but it's also a significantly different platform than the aspen. Really the only way you can compare the Aspen to the G600 is if you go with the PFD + 2 MFD setup that Aspen has. If you look at it from that perspective it's much closer to comparing apples-to-apples and the price is comparable also. |
Similar Threads | ||||
Garmin G600 | Mike Isaksen | Piloting | 8 | October 18th 07 12:15 AM |
Garmin G600 | Alex M. (Mooney in California) | Owning | 6 | May 5th 07 04:38 PM |
XM Wx Garmin 430/430W with Garmin GDL-69? | [email protected] | Instrument Flight Rules | 4 | March 5th 07 03:52 AM |
This is why Garmin 296's street price has been dropping -> Garmin 396 | [email protected] | Instrument Flight Rules | 7 | July 11th 05 06:39 PM |
FA: Garmin 195 | JerryK | Aviation Marketplace | 1 | September 8th 03 09:41 PM |
