Changing ADF frequencies in 0.5 increments
Old September 8th 03, 02:05 AM
Damos
Default Changing ADF frequencies in 0.5 increments
Trying to set 349.5 ADF frequency but unable to get the last 0.5 This
is an issue mention my a previous poster a couple of years ago but no
solution was offerd.
In a PCPilot magazine, an author of a tutorial mentioned that "when
you set up a flight simulator such as fs2002 its wise to opt for the
half frequency option" But doesn't mention how this is done. (neither
does the help menu offer anything.)
Suggestions
D.
Old September 8th 03, 02:17 AM
Brett Holcomb
If I remember correctly it's in one of the options or aircraft menu - try
the option first. My FS system isn't up right now.
Suggestions
D.
Brett I. Holcomb
Microsoft MVP
AKA Grunt
Remove R777 to email
Old September 8th 03, 11:46 PM
Damos
The option menu (when flying) only gives me
(general/display/international/ATC) which are no different to the
settings options in startup menu. Can't see anything which refers to
instruments or frequencies.
??do you have extra options (using fs2002 pro)
D.
Brett Holcomb wrote in message ...
Suggestions
D.
Old September 9th 03, 01:31 AM
Brett Holcomb
I can't find it now! Did you check under Aircraft menu. I don't have a
system that runs FS2002 Pro anymore - Windows decided to die on that one so
I haven't reinstalled it yet. I couldn't find it on FS2004 either.
D.
Damos wrote:
Brett I. Holcomb
Microsoft MVP
AKA Grunt
Old September 9th 03, 11:15 PM
Damos
Options that I can call up while flying dont mention anything to do
with frequencies.
Aircraft menu
Select aircraft (tries cesna172 with IFS panel - no change)
Kneeboard
Navigation (EFIS optio not change anything)
Fuel
Realism settings (nothing here either)
System failures (nothing setup to fail)
Slew Mode (not realy apply)
Alex
I can select up to frequency 1699.0 on ADF at the moment
Hoping that I'm not going to have to try a reinstall.....
?was there an option at install asking what frequency we want setup?
D.
Alex D. Nicolson wrote in message . ..
No longer have Fs2002 Pro installed but if my ancient memory serves -
the 0.5 khz facility is brought up by extending the ADF coverage to
1700 khz. How this was done I cannot presently recall. I always
enabled it as I don't fly in the US. Someone else is sure to come up
with an answer...
Alex
D.
Suggestions
D.
Old September 12th 03, 12:56 AM
Alex D. Nicolson
Odd.
My original comment referred to Fs98...
Fs2000 had the Increments as a selectable Option on "Instruments".
A search of my Fs2002 documentation has nothing, suggesting it is
available automatically by the ADF receiver - as is currently done in
Fs2004.
Try changing your ADF to a different more recent gauge model - some of
the older ADF receiver gauges did have this specific problem.
Best
Alex
with frequencies.
Aircraft menu
Kneeboard
Fuel
Alex
Old September 15th 03, 10:04 PM
Damos
Well in the end I just reinstalled fs2002 and can now chnage the adf
in 0.5 increments. The radiostack panels are different so it appears
that the stack file must have been changed when I installed a new
plane.
Thanks for your suggestions
D.
Odd.
Fs2004.
Best
Alex
with frequencies.
Aircraft menu
Kneeboard
Fuel
Alex
Old September 21st 03, 01:10 PM
Mark Cherry
In om,
Suggestions
In FS98 the 0.5 ADF option was on the same menu page as the 0.025 COM freqeuncy
option, plus one or two other items.
I think it was under Options...Preferences but I'll check, next time I run it
and send another post later.
I expect to be running FS2002Pro on a new PC by next week, so I'll go looking
for options like this during the install and let you know what I find.
regards,
Mark
Scanner frequencies for Oshkosh? Greg General Aviation 1 July 21st 04 04:40 PM
which frequencies are all? Arden Prinz Piloting 32 May 11th 04 03:38 PM
Howie Keefe's Topo Atlas/WAC charts & frequencies Mark Piloting 10 December 1st 03 02:36 PM
Approach Control Frequencies John General Aviation 5 October 18th 03 09:30 AM
Approach Control Frequencies John Owning 10 October 5th 03 12:16 PM
