Pegase cruise speeds
Old August 27th 18, 01:48 PM posted to rec.aviation.soaring
Mark Williams
Default Pegase cruise speeds
I have a share in a Peg 90. I feel that over 65/70kt the LD really drops off, though, I don't have evidence for this and hope it's higher What do others think?
Mark
Old August 27th 18, 03:18 PM posted to rec.aviation.soaring
Martin Gregorie[_6_]
do others think?
From memory, best glide for a peg 90 is 55kts, so anything up to 70kts
won't loose you much height. Its been a while, but IIRC we generally
thought that up to 80-85 kts was OK but height tended to slip away if we
went much faster (and the equivalent number for a Discus 1 was 90kts).
FWIW my Std Libelle runs at 70kts without much height loss and it doesn't
come down all that fast at 80kts.
But don't take my word for it, if your vario can calculate glide ratio
and has a super netto mode[1] (my SDI C4 does and its 'cruise' mode is
super netto) have a play round next time you're reasonably high in calm,
minimal lift conditions. You should find that you can guestimate a usable
polar by flying at, say, 60, 70, 80, 90, 100kts and noting the glide
ratio on the vario when the super netto mode shows zero.
If your vario won't do that, in minimal lift conditions try flying at
these speeds for one or two minutes each with your logger running,
preferably at 1 second intervals. Then calculating the glide ratio from
the IGC log file for each of these segments. It will be a bit of a faff,
but should be doable.
[1] super netto mode adds the glider sink rate (calculated from the polar
you put into the vario) to the TE value, to show what the air mass is
doing, so a zero super-netto reading should mean the air mass isn't
rising or sinking.
For an actual example of what a Peg 90 can do in early evening air, read
this:
https://www.gregorie.org/gliding/200...nals/day8.html
The second to last paragraph in this story (just above the plotted trace)
describes the final glide, 40 km back home starting from 5300 ft, in what
felt like very calm air: no noticeable lift or sink and only a bit of
cross-track drift.
Martin | martin at
Gregorie | gregorie dot org
Old August 27th 18, 03:28 PM posted to rec.aviation.soaring
I have about 2,100 hours in the Pegase 101A, and I always looked at 80 knots (unballasted) as the speed where L/D really dropped off. (Or 90 knots when flying ballasted and at Max Gross Weight) Since I fly in New Mexico in relatively strong conditions, I tend to push those speeds even higher on occasion if conditions warrant. (I made a 500 km flight in 4 hours flat, launch to landing, which is an average of 67.5 knots. Factor in the tow and thermal climbs, and the average speed was obviously much higher.) On a strong, high altitude cloudstreet, 100+ knot cruise speeds are great fun. Naturally, trying to fly that fast in other parts of the country will ensure many introductions to (hopefully) friendly farmers.
Old August 28th 18, 12:28 PM posted to rec.aviation.soaring
Mark Williams
Thanks Martin and Mark. I shall do some experimenting, hopefully on a late afternoon with a long final glide with plenty of margin.
Spinning a Pegase Dan S Soaring 14 April 10th 18 05:31 PM
Right pegase aileron Ollie Sleigh Soaring 0 August 10th 16 08:49 PM
Inter-thermal cruise speeds? Frank[_1_] Soaring 25 February 25th 08 12:55 AM
real cruise speeds [email protected] Home Built 1 January 20th 08 02:11 AM
pegase 101d Eddy Van Roon Soaring 0 May 13th 05 08:07 PM
