Std. Libelle water ballast system
Old April 8th 21, 09:47 PM posted to rec.aviation.soaring
Default Std. Libelle water ballast system
I bought my second Std. Libelle, s/n 593 so it is a balasted ship ex-factory. A 201B.
It has waterbags, the dumplever but no valve in the wheel well and no holes in the bulkhead behind the seat and the wheel well.
Not a trace of it...
It has seen extensive damage the two years after it was delivered new.
The first repair consisted of the complete new cockpit section, it might explain things but I cannot imagine it hasn't flown ballasted the last 46 years.
What do I miss?
The ships I know are in the 100, 200 and 300 build number range.
I never saw other late serial ships.
Old April 8th 21, 10:01 PM posted to rec.aviation.soaring
Sean E
What do I miss?
You said the ship had extensive damage, I would recommend reviewing the current weight and balance to make sure you can add more ballast, if you haven't already done so.
Sean
Old April 8th 21, 10:48 PM posted to rec.aviation.soaring
Martin Gregorie[_6_]
ex-factory. A 201B.
last 46 years.
What do I miss?
After you've sorted out the W&B, contact Glasfaser, if you haven't
already done so. I've found them to be easy to deal with and helpful.
They probably have the drawings you need and may be able to supply the
missing water dump parts too.
Web: http://www.streifly.de/
E-mail:
Martin | martin at
Gregorie | gregorie dot org
Old April 9th 21, 01:58 AM posted to rec.aviation.soaring
Dave Nadler
I thought only us motor-glider types need a spare glider?
Very confusing.
Looking for water ballast system for DG 200 complete and or parts of. Chris Stratton Soaring 4 February 11th 20 08:31 PM
ASW 17 water ballast system OregonGliderPilot Soaring 2 August 18th 19 04:55 PM
Wanted: Libelle water ballast fittings JS Soaring 0 April 6th 13 05:42 PM
Libelle 301 water ballast [email protected] Soaring 3 January 15th 08 02:40 PM
Who first used water ballast and when? John McCullagh Soaring 9 October 18th 06 09:36 AM
