#21
what is that noise?
I've heard that in hundreds of videos, more often in two seaters. Watch a few Duo Discus vids, you'll see what it mean. I believe it's almost certainly the spar stubs rubbing.
what is that noise?
Le lundi 22 juillet 2019 12:39:11 UTC+2, gregv a Ă©critÂ*:
Hello, I fly a 1979 Nimbus 2 carbon, and since a few years I hear a cracking noise behind me. That noise occurs more often after a few hours of flight, maybe related to temperature change with altitude. You can hear the cracking noise in this video: https://www.youtube.com/watch?v=pke-...ature=youtu.be Did you already hear that noise? how do you think I can fix this ? do you think it is dangerous? Thank you for help and advice Ok so I checked carefully the glider on the ground and I seems I could reproduce the noise. Lift Pins and bearings are ok, no rubbing clue on the spar neither on the fuselage. The noise is not related to outer wings. When the airbrakes are open, there is no more noise... so it must be related to airbrakes... I can hear the noise coming from the airbrakes / flaps, and if I put my hand on them as they are closed and that I put the wing for and aft I can hear and feel the noise with my hand. When I inspect the airbrakes mechanism everything seems ok. Strange thing is that the noise is symetrical on both wings. |
what is that noise?
On Sat, 27 Jul 2019 06:32:03 -0700, gregv wrote:
Ok so I checked carefully the glider on the ground and I seems I could reproduce the noise. Lift Pins and bearings are ok, no rubbing clue on the spar neither on the fuselage. The noise is not related to outer wings. When the airbrakes are open, there is no more noise... so it must be related to airbrakes... I can hear the noise coming from the airbrakes / flaps, and if I put my hand on them as they are closed and that I put the wing for and aft I can hear and feel the noise with my hand. When I inspect the airbrakes mechanism everything seems ok. Strange thing is that the noise is symetrical on both wings. If that was my glider (I'm in the UK) I'd being asking the inspector who does my Annual Inspection to take a look at it. Doing that in the past has both found problems I've missed and shown that things I asked him about were non-problems. -- Martin | martin at Gregorie | gregorie dot org |
what is that noise?
the wing for and aft I can hear and feel the noise with my hand. When I inspect the airbrakes mechanism everything seems ok. Strange thing is I'm reading this as you pull/push the wing tips for and aft and feel the noise in the airbrake system. If so, how much force, how much do the wing tips move and is there a spec limit for this in the poh or maint manual? |
what is that noise?
On my DG200 fore and aft play in the wings is eliminated by shimming the lift pins. If a shim has come loose, and dropped of it could cause such issues.
what is that noise?
What, if anything is supposed to hold the shims in place when the glider is in the unassembled state?
On Monday, July 29, 2019 at 11:00:28 PM UTC-5, Charlie Quebec wrote: On my DG200 fore and aft play in the wings is eliminated by shimming the lift pins. If a shim has come loose, and dropped of it could cause such issues. |
what is that noise?
On Tuesday, July 30, 2019 at 8:53:21 AM UTC-4, wrote:
What, if anything is supposed to hold the shims in place when the glider is in the unassembled state? On Monday, July 29, 2019 at 11:00:28 PM UTC-5, Charlie Quebec wrote: On my DG200 fore and aft play in the wings is eliminated by shimming the lift pins. If a shim has come loose, and dropped of it could cause such issues. Gliders with removable lift pins have the shims under the shoulder of the pin. UH |
#28
what is that noise?
My Mini Nimbus creaks on hot days -- more if it's been left out in the sun
before launch. It sounds like flexing plastic to me, and I've always put it down to the canopy expanding/contracting a different amount to the fus. I think it goes away eventually in flight (or at least, I tend to only notice it at first). Your video sounds more like a banging noise, but it's hard to tell from the video... it could be the same creaking perspex noise I hear. J At 13:52 30 July 2019, wrote: On Tuesday, July 30, 2019 at 8:53:21 AM UTC-4, wrote: What, if anything is supposed to hold the shims in place when the glider is in the unassembled state? On Monday, July 29, 2019 at 11:00:28 PM UTC-5, Charlie Quebec wrote: On my DG200 fore and aft play in the wings is eliminated by shimming the lift pins. If a shim has come loose, and dropped of it could cause such issues. Gliders with removable lift pins have the shims under the shoulder of the pin. UH |
#29
what is that noise?
I agree with a earlier poster that I would look in the airducting system Sounds like a vent cover or something hard but loose in the airflow.
#30
what is that noise?
The howling in the tail boom might be from air pressure coming in and it doesn’t have a escape.
You can try leaving the wing tape off at the trailing edge about one inch. It helped on my Lak. W7 |
Similar Threads | ||||
FAA paper Noise Attenuation Properties of Noise-Canceling Headsets | Jim Macklin | Piloting | 26 | January 13th 07 12:06 AM |
FAA paper Noise Attenuation Properties of Noise-Canceling Headsets | Jim Macklin | Instrument Flight Rules | 15 | January 13th 07 12:06 AM |
Prop noise vs. engine noise | Morgans | Piloting | 8 | December 24th 03 03:24 AM |
noise | G.A. Seguin | Soaring | 2 | August 27th 03 01:57 AM |
Com noise | Hankal | Piloting | 0 | July 21st 03 12:54 AM |
