Fuel sender gaskets???
I'm replacing the fuel sender gaskets to cure a leak. The old gaskets
show evidence of extrusion due to overtightening the screws. How tight should the screws be? (Tight enough to seal, but not tight enough to deform/cut the gasket?) Should I use any form of gasket cement between the steel face of the sender and the gasket? Between the gasket and the aluminum surface on the tank? MikeM |
The only gasket sealer that i would use is Proseal. It's totally fuel proof.
mikem wrote: I'm replacing the fuel sender gaskets to cure a leak. The old gaskets show evidence of extrusion due to overtightening the screws. How tight should the screws be? (Tight enough to seal, but not tight enough to deform/cut the gasket?) Should I use any form of gasket cement between the steel face of the sender and the gasket? Between the gasket and the aluminum surface on the tank? MikeM |
mikem wrote:
I'm replacing the fuel sender gaskets to cure a leak. The old gaskets show evidence of extrusion due to overtightening the screws. How tight should the screws be? (Tight enough to seal, but not tight enough to deform/cut the gasket?) Should I use any form of gasket cement between the steel face of the sender and the gasket? Between the gasket and the aluminum surface on the tank? MikeM When I put a new fuel cell in my airplane last year it came with all the gaskets including the sender gasket. It was cork and I used a light coat of Vaseline only. They shouldn't need any sealer. The torque spec should be in the maint manual, but its not much. Also retorque after 24 hrs as the gasket 'sets'. |
kontiki wrote: When I put a new fuel cell in my airplane last year it came with all the gaskets including the sender gasket. It was cork and I used a light coat of Vaseline only. The gaskets are rubber. When I opened the wing bay at annual this year, the leak was obvious. Three years ago when the senders were replaced, we put new gaskets in with a thin film of "FuelLube". They leaked just enough to stain the fuel tank and put a fuel smell into the cockpit and hangar. The gaskets have developed cracks around the screw holes, probably because the screws were overtightened, so they must be replaced. I dont want to be doing this again... |
Similar Threads | ||||
Time, running out of fuel and fuel gauges | Dylan Smith | Piloting | 29 | February 3rd 08 07:04 PM |
I want to build the most EVIL plane EVER !!! | Eliot Coweye | Home Built | 237 | February 13th 06 03:55 AM |
Most reliable homebuilt helicopter? | tom pettit | Home Built | 35 | September 29th 05 02:24 PM |
Mini-500 Accident Analysis | Dennis Fetters | Rotorcraft | 16 | September 3rd 05 11:35 AM |
Is Your Airplane Susceptible To Mis Fu eling? A Simple Test For Fuel Contamination. | Nathan Young | Piloting | 4 | June 14th 04 06:13 PM |
