Piper Seneca II Alternator circuit problem
Old June 5th 17, 02:39 AM posted to rec.aviation.owning
George Jerome
Default Piper Seneca II Alternator circuit problem
I have a 1980 Piper Seneca II owned since 1985.
I am having a problem with the alt warning light. It is intermittent, and burns up the 6 watt 50 ohm resistor located on the enunciator panel. This was never a problem - started very recently. The service manual shows the circuit, but no details or part numbers for the resistors, or any other components in this circuit.
It appears to me that this could be an alternator issue [they are out for test, but both failing at the same time? Not likely]
It could be the ammeters, but again, both at once?? Crazy expensive to replace.
We have replaced the resistors [found a part number], but same issue.
Any thoughts on how to track down the culprit?? I would appreciate all comments.
Alternator (Ammeter) Problem (Piper) [email protected] Owning 3 October 29th 18 08:55 PM
Engine problem - Seneca II BDS Piloting 22 January 8th 07 04:07 PM
Piper Seneca Frode Berg Owning 15 April 22nd 06 01:42 PM
Piper Seneca, In Soo Piloting 1 December 30th 04 01:25 PM
I am going to do it again! A Piper Seneca? Michelle P Owning 5 August 20th 03 01:59 AM
