Emergency Landing-Engine DEAD
Old June 19th 08, 12:03 PM posted to rec.aviation.piloting
More_Flaps
Default Emergency Landing-Engine DEAD
On Jun 19, 3:23*pm, Dudley Henriques wrote:
Larry Dighera wrote:
On Wed, 18 Jun 2008 22:50:25 -0400, Orval Fairbairn
wrote in
Also, grass runways cut tire and brake wear *WAY down!
I would expect sod strips to be ideal for learning to master landing a
tail-wheeled *aircraft.
In checking pilots out in a Pitts, I always had them use the grass first
and get REALLY proficient with the roll out behavior of the airplane
before sending them on to a hard surface. Grass was MADE for a Pitts! :-))
In my limited experience the key to a good FLWOP is planning the 1000'
and 2000' points. If you nail them the glide approach is much more
straightfoward.
my 2c
Cheers
  #32
Old June 19th 08, 01:27 PM posted to rec.aviation.piloting
Dylan Smith
On 2008-06-18, Orval Fairbairn wrote:
Most of the Bo (and other higher-performance singles) never practice
engine-out emergencies. They also tend to fly approach at far too-high
airspeed.
In the case of an engine out, a higher approach speed might be
necessary. IIRC, I used to be on short final in an S-35 Bonanza at 65
knots IAS with full flaps, but I had some power on. The S-35 manual
cautioned the pilot to approach 10 knots faster in the case of engine
failure, to have sufficient energy for the flare. The sink rate in a
power off approach is also higher, it really does look like the ground
is coming up to smite you. If you've never landed one power off before
this could be a bit startling and induce the pilot to flare too early.
From the sunny Isle of Man.
Yes, the Reply-To email address is valid.
  #33
Old June 19th 08, 02:18 PM posted to rec.aviation.piloting
Peter Dohm
"Dylan Smith" wrote in message
airspeed.
That makes a lot of sense. The one time that I was along in a Bellanca
Viking for a radically reduced power approach, the descent rate and angle
were dramatically greater than a normal approach in the same airplane. That
was still with the engine just above idle--rather than windmilling.
Peter
  #34
Old June 19th 08, 03:52 PM posted to rec.aviation.piloting
Orval Fairbairn[_2_]
airspeed.
That is why you need to PRACTICE!
Remove _'s from email address to talk to me.
  #35
Old June 19th 08, 03:57 PM posted to rec.aviation.piloting
airspeed.
Peter
I do it all the time in my Johnson Rocket. Approach at 80 mph, descent
indicated 2000-3000 fpm.
Come overhead at 160, break, pull power back during the break, slow to
100 mph gear/flap speed, drop the gear, hold 80 mph, turn tight base,
full flaps on final, start the flare about 30-50 ft, grease it on in a
full stall.
Yes, the ground DOES come up fast -- especially with a significant
headwind, but it all becomes routine with practice.
  #36
Old June 21st 08, 12:49 AM posted to rec.aviation.piloting
Cubdriver
On Wed, 18 Jun 2008 18:29:12 -0500, Jim Logajan
What makes turf airstrips fun?
I believe he means that, as a general rule, it's their locations that make
them more fun than paved ones.
Grass is MUCH easier to land on than asphalt, especially in a
taildragger. The additional friction seems to rule out the possibility
of a ground loop, and there's no revealing SQUEAK when you touch down.
Blue skies! -- Dan Ford
Claire Chennault and His American Volunteers, 1941-1942
new from HarperCollins www.FlyingTigersBook.com
  #37
Old June 21st 08, 12:56 AM posted to rec.aviation.piloting
Larry Dighera
On Fri, 20 Jun 2008 19:49:52 -0400, Cubdriver usenet AT danford DOT
net wrote in :
of a ground loop,
You believe that rubber tires have more traction in turf than they do
on asphalt?
  #38
Old June 21st 08, 03:40 AM posted to rec.aviation.piloting
net wrote in :
of a ground loop,
on asphalt?
The main gear, with less traction has a reduced tendency to create a
groundloop, while the tailwheel has extra drag, which stabilizes the
landing.
  #40
Old June 23rd 08, 10:12 AM posted to rec.aviation.piloting
Dylan Smith
net wrote in :
of a ground loop,
on asphalt?
Grass is draggier BUT you have less traction on it. That's why it's more
forgiving in a tailwheel plane - you'll slow faster with less brakes,
but if you touch down slightly sideways the wheels will tend to slip.
If you've ever ridden a bicycle from a tarmac surface to a grass
surface, you'll grok the difference.
Emergency Landing on I-70! Darkwing Piloting 19 February 26th 08 03:56 PM
The emergency landing checklist Dave Kearton Aviation Photos 1 April 28th 07 07:35 AM
Emergency landing theoretical gatt Piloting 21 May 15th 06 03:07 PM
Live emergency landing on tv right now C. Massey Piloting 7 May 4th 06 02:49 AM
single-engine turboprop emergency landing in Indiana Kyler Laird General Aviation 4 December 29th 04 06:42 AM
