vibration of duodiscus after winch launch
Old May 2nd 18, 08:32 PM posted to rec.aviation.soaring
Paolo Guardigli
Default vibration of duodiscus after winch launch
Hello everybody,
we in my Club(Pavullo in Italy) are suffering(2 times) a very strange vibration of the duodiscus for a minute or so after the glider is released from the rope,after one minute the vibration is finishing.
We are trying to investigate why it happened but we are not able to find out the reason.
Does someone already experienced the same problem?
Thanks a lot to everybody
Paolo Guardigli
Old May 2nd 18, 09:58 PM posted to rec.aviation.soaring
AS
On Wednesday, May 2, 2018 at 3:32:35 PM UTC-4, Paolo Guardigli wrote:
Hello everybody,
Paolo Guardigli
Hello Paolo - can you be a bit more specific about that vibration? What is the estimated frequency of that vibration - low, high?
What is vibrating? The wings, the tail-boom or ??
Uli
'AS'
Old May 2nd 18, 10:45 PM posted to rec.aviation.soaring
Martin Gregorie[_6_]
Hello everybody,
Paolo Guardigli
Could it be that the nosewheel got spun-up during the ground run and is
still spinning after release? I'm pretty certain I've noticed that once
or twice in an ASK-21 when the glider wasn't balanced on its main wheel
soon enough.
Martin | martin at
Gregorie | gregorie dot org
Old May 3rd 18, 04:39 PM posted to rec.aviation.soaring
Paolo Guardigli
Hello everybody,
Paolo Guardigli
Uli
'AS'
According the feeling(that is difficult to say precisely it seems the vibration comes from the tail (bottom)
Old May 3rd 18, 06:51 PM posted to rec.aviation.soaring
Piet Barber
I can't imagine a scenario where the nose wheel of a Duo Discus would touch the ground on a winch launch. The tail wheel, though -- you might be on to something.
I'd try to replicate the scenario on the ground. Have two [heavy!] people get into the cockpit, close the canopy, get the tail boom up off the ground and find a way to get the tail wheel to spin up to a good speed. See if the tail wheel is what's making the noise. If after the take-off the tail wheel is still spinning, and slowing down, making noise the whole time.
Hello everybody,
Paolo Guardigli
soon enough.
Martin | martin at
Old May 4th 18, 01:40 PM posted to rec.aviation.soaring
Paolo Guardigli
Hello everybody,
Paolo Guardigli
soon enough.
Martin | martin at
thanks
Old May 6th 18, 02:24 AM posted to rec.aviation.soaring
Karl Striedieck[_2_]
I had a similar event after a auto launch last weekend. After release there was a weird vibration/buzz/whine/etc. and I figured it was the main wheel so squeezed the brake handle. No change. After landing just we rolled to a stop and the tail dropped back to earth I heard that sound again. Obviously it was the tail wheel spinning down, and in the case of the Duo XL that component is a heavy brass item (for cg) and takes a long time to unwind.
If your Duo has a brass tailwheel I'd bet that's what you heard.
KS
Old May 6th 18, 05:43 AM posted to rec.aviation.soaring
Jeff Morgan
On a winch launch you want to get to your climbing speed before laying back into the stick. In other words, no early back stick.
And even then, a winch launch lasts all of about 40 seconds. Assuming your were back on the stick too much too early and spun the tail wheel - it will stop being spun when you leave the ground (about 2 seconds into launch) and should be mostly spun down at time of release.
Regardless of technique, a balanced wheel will spin down smoother. Any way to check the wheel balance on the tail wheel?
Old May 7th 18, 06:55 AM posted to rec.aviation.soaring
2G
It may have to do with bearings used than the balance.
Tom
Old May 7th 18, 01:14 PM posted to rec.aviation.soaring
KS
We regularly hear a similar "spin down" noise from the tail wheel of our ASK-21 after takeoffs and landings.
UH
Winch Launch - Fatal Jock Proudfoot Soaring 65 December 19th 16 08:57 PM
Winch Launch School Karl Striedieck[_2_] Soaring 1 January 7th 16 03:10 PM
Winch Launch Videos Mike Schumann Soaring 2 January 19th 06 11:27 PM
LIppmann reports a 950 meter winch launch with their Dynatec winch line - anything higher? Bill Daniels Soaring 20 December 27th 04 12:33 AM
Winch launch M B Soaring 0 October 30th 03 07:33 PM
