Aileron "tuning" or "trimming"
Old May 27th 18, 01:03 PM posted to rec.aviation.soaring
Default Aileron "tuning" or "trimming"
Hi all,
I have a PW-5 that requires side pressure on the stick at all times to correct a tendency to bank to the right. More pronounced at higher speeds, of course. Wing tape helps a little but doesn't eliminate it. But there is a visible tiny difference in aileron position from one side to the other when the stick is neutral.
Planning to pull out the manual and figure out how to make length adjustments to the control rods, but is there any counterintuitive thing I should know before attempting to fine-tune?
Cheers,
Chris
Old May 27th 18, 01:56 PM posted to rec.aviation.soaring
On Sunday, May 27, 2018 at 8:03:36 AM UTC-4, wrote:
Hi all,
Cheers,
Chris
A few things to start with:
First-Before doing anything look in the maintenance manual to see if there is any information on how ailerons should be rigged.
Next, align one aileron in "neutral". Then check to see if the other is in neutral. Stick position does not matter.
If they do, fly the ship and see if it flies straight. Again stick position does not matter for this test.
If it flies straight, then adjustments to the control mechanism may be made to get stick centered.
If they do not line up, the mechanism may need adjustment to make them line up.
If it does not fly straight with ailerons even and in neutral the problem likely is in the rigging of the wings. There may be a way to correct this. See the manual.
All this should be done with the help of your mechanic.
Good luck
UH
Old May 27th 18, 04:03 PM posted to rec.aviation.soaring
It could be a warped wing, there was an article years ago in Australian Gliding detailing a similar problem with a Mosquito, which was cure by heating the wing in a large oven whilst twisted back
allowing it to cool a couple of times.
Ige seen small aluminium tabs on ailerons used to correct minor issues.
Old May 27th 18, 05:45 PM posted to rec.aviation.soaring
Dan Daly[_2_]
Is there play in the aileron when the stick is held steady?
How many hours on the glider?
Old May 27th 18, 10:01 PM posted to rec.aviation.soaring
There is a useful tool on the iphone compass, if you swipe the compass, a rather good inclinometer is there.
Very easy to check such things as aileron and flap positions and travel.
Old May 28th 18, 12:36 AM posted to rec.aviation.soaring
Matt Herron Jr.
On Sunday, May 27, 2018 at 5:03:36 AM UTC-7, wrote:
Hi all,
Cheers,
Chris
this is counter intuitive. Check that the horizontal stab is properly aligned. I had the same problem in my Ventus. At high speeds it would need stick pressure to keep the thing flying level. Rex at Williams Soaring Center suggested the stab, checked it with a laser, and it was indeed out a little bit. He trued it up (somehow) and the problem went away.
I don't think ailerons out of alignment would cause this. The stick will just find a neutral position that is not perfectly centered, but it shouldn't cause bank. warped wings would though. Does it always drop the same wing when you stall it?
Matt
Old May 28th 18, 01:10 PM posted to rec.aviation.soaring
I have exactly the same problem in my PW-5. Also to the right. Our mechanic looked over the ailerons and couldn't see anything wrong with their alignment or any looseness.
My PW-5 has about 300 hours TT.
Obviously I'm interested in how you finally solve this one.
Old May 28th 18, 02:25 PM posted to rec.aviation.soaring
I'd look for anything causing drag on the right wing, could be loose aileron gap tape where the leading edge is forced up under air loads or poorly seated spoiler on the right wing. As noted, right turn has nothing to do with zero ailerons or stick position. If unable to find the cause, a small aluminum trim tab (bent up) placed on the trailing edge of the right aileron will make the aileron fly slightly down and counteract the right turning tendency...........but this remedy will add some drag!
Hope this helps,
JJ
Old May 28th 18, 04:42 PM posted to rec.aviation.soaring
Mike the Strike
Hope this helps,
JJ
I think JJ's answer is most likely to be correct. I had this symptom on my ASW20 and everything looked fine until I did winter maintenance to polish the wings and replace gap tape. I discovered one lower gap tape had come partially unglued and lifted a little in flight, acting like a little flap. Replacing the tape with fresh cured the problem.
Old May 28th 18, 05:49 PM posted to rec.aviation.soaring
Nick Kennedy
JJ
What size trim tab would be good for a slight turn?
What proportions that stick out in the wind is your wild ass guess?
Nick
What are the Pros and Cons of using the "ForeFlight Mobile EFB" appin Sailplanes as opposed to, say, "iGlide" or "navITer" ? jstodaro Soaring 4 March 26th 17 05:04 PM
"VideO Madness" ( Soldiers...) "GoD Hates FAGS!!! (He sO righteOusly DoES)" Colonel Jake Naval Aviation 0 March 1st 10 12:14 AM
Old polish aircraft TS-8 "Bies" ("Bogy") - for sale >pk Aviation Marketplace 0 October 16th 06 07:48 AM
