Cessna 172R from Telluride to Aspen
Old May 10th 08, 10:20 PM posted to rec.aviation.piloting
Benjamin Dover
Default Cessna 172R from Telluride to Aspen
Mxsmanic wrote in
Viperdoc writes:
Are you referring to a real airplane or simulated flight with MSFS?
I'm asking about real airplanes, subsequent to a simulated flight with
the same aircraft that ended tragically just a few minutes ago,
probably due to icing, although I'm not sure. I tried the flight as
an experiment to see if it was possible, and I'd like to know from
pilots of the real aircraft whether or not it would be possible or
safe to attempt it in real life.
Weather at Aspen was low IFR so I had planned to divert to Garfield
County, but I lost control of the aircraft about 20 miles southeast at
12500 feet and impacted terrain.
Wow. Our resident ace pilot can't even fly a 172 on his simulator! I
wonder who give him directions on how to pee.
Old May 10th 08, 10:23 PM posted to rec.aviation.piloting
Benjamin Dover
"Viperdoc" wrote in
You didn't include the area forecast and any sigmets or airmets. What
is the climb rate in a 172 for the given W/B at the temperature and
altitude you mentioned?
Do you really expect MXSMORON to do any sort of flight planning? His
concept of pre-flight checks is to make sure his computer is plugged in and
then hit power on. He doesn't even know that he should kick the tires
before he lights the fires.
Old May 10th 08, 10:45 PM posted to rec.aviation.piloting
More_Flaps
On May 11, 9:20*am, Benjamin Dover wrote:
Mxsmanic wrote :
Viperdoc writes:
probably due to icing, although I'm not sure. *I tried the flight as
Wow. *Our resident ace pilot can't even fly a 172 on his simulator!
In this case the output of the game had a modicum of accuracy, MX
would have crashed a real 172 also.
Cheers
Old May 10th 08, 10:58 PM posted to rec.aviation.piloting,alt.usenet.kooks,alt.alien.vampire.flonk.flonk.flonk
Bertie the Bunyip[_25_]
"Maxwell" luv2^fly99@cox.^net wrote in news:bVoVj.85$yP7.41
@newsfe18.lga:
He would have had to start , taxi and take off first, all of which
seems
pretty unlikely.
Bertie
Yeah, but a lot of **** seems unlikely to you Buttlipp.
Yes, like you ever getting a clue, for instance.
Bertie
Old May 10th 08, 10:59 PM posted to rec.aviation.piloting
Maxwell[_2_]
He would have had to start , taxi and take off first, all of which seems
pretty unlikely.
Bertie
Old May 10th 08, 11:00 PM posted to rec.aviation.piloting
More_Flaps
On May 11, 9:53*am, Bertie the Bunyip wrote:
Mxsmanic wrote
innews:c8jb24l6tsh3td76a8s020c08icujj2
Viperdoc writes:
MSFS?
with the same aircraft that ended tragically just a few minutes
ago, probably due to icing, although I'm not sure. *I tried the
flight as an experiment to see if it was possible, and I'd like to
know from pilots of the real aircraft whether or not it would be
possible or safe to attempt it in real life.
at 12500 feet and impacted terrain.
pretty unlikely.
Good point.
BTW I'm starting aerobatic lessons in a Citabria next week... WhooHoo!
When are you going to get yours going? Any vices I should be warned
about?
Cheers
Old May 10th 08, 11:01 PM posted to rec.aviation.piloting
More_Flaps
On May 11, 9:59*am, "Maxwell" luv2^fly99@cox.^net wrote:
"Bertie the Bunyip" wrote in 6.130...
pretty unlikely.
Bertie
Could you be quiet please, Bertie and I are discussing flying?
Cheers
Old May 10th 08, 11:07 PM posted to rec.aviation.piloting
Bertie the Bunyip[_24_]
More_Flaps wrote in
More_Flaps wrote
innews:65c674c2-4c8a-440e-8967-f72d
Viperdoc writes:
MSFS?
flight with the same aircraft that ended tragically just a few
minutes ago, probably due to icing, although I'm not sure. *I
tried the flight as an experiment to see if it was possible, and
I'd like to know from pilots of the real aircraft whether or not
it would be possible or safe to attempt it in real life.
Garfield County, but I lost control of the aircraft about 20
miles southeast at 12500 feet and impacted terrain.
simulator!
seems pretty unlikely.
Good point.
about?
Should be flying in about three more weeks or so. The airplane itself is
pretty easy to fly as an airplane. If you haven't flown any old
tailwheel airplanes or gliders you will have to wake your feet up a bit
just for the normal manuevering. It's pretty much a textbook airplane,
though. If he doesn't say it to you , be as smooth as you can in
everything you do. that doesn't neccesarily mean slow, but you'll always
get more performance if you're smooth.
Bertie
Old May 10th 08, 11:12 PM posted to rec.aviation.piloting
Mxsmanic
Viperdoc writes:
I didn't check them, although I looked at the current and forecast weather for
the several airports that interested me.
Do you know the answer to my question or not? You shouldn't need radar tracks
or a FDR just to reply.
It's still light outside ... I think I'll try it in the Baron, although I'm
pretty sure that it will be easy in that aircraft, if the weather isn't too
bad.
Uncontrolled Engine Compartment Fire Possible for Cessna 172R, 172S, 182T, T182T, 206H, and T206H Models Larry Dighera Piloting 0 April 19th 07 04:31 PM
'99-'00 172R vs 172SP: R is good? or the weak little brother? XrayYankee Owning 9 May 1st 06 06:07 AM
C-172R to SP upgrade Greg Farris Owning 5 May 6th 05 10:17 AM
172P vs 172R for instrument platform..... Jonathan Instrument Flight Rules 6 July 22nd 04 01:52 AM
FS: 1997 Cessna 172R Alan Adamson Aviation Marketplace 1 June 1st 04 12:57 PM
